Support Chinese words?
EddyLin
Post by EddyLin » Fri Aug 07, 2020 5:42 pm
I have test dwg2svg but I found all my Chinese words become ?????????.
Will you support Chinese words?
Re: Support Chinese words?
Post by andrew » Fri Aug 07, 2020 6:25 pm
Please attach or e-mail your DXF and SVG, so we can see if the problem is in the DXF, the SVG or the SVG viewer.
EddyLin
Post by EddyLin » Sat Aug 08, 2020 6:21 pm
Due to the copy rights issue I have sent an email to [email protected]. Please help to solve my problem. Thanks.
Post by andrew » Mon Aug 10, 2020 8:44 am
The file uses fonts "romans" and "romanc", both don't define Chinese or other international glyphs.
For this file, I'd recommend the following options (substitute fonts):
./dwg2svg -fs romans Arial -fs romanc Arial -f -o output.svg input.dwg
This is assuming that your system has an Arial font installed with support for Chinese glyphs.
To keep text as text in SVG add -g:
./dwg2svg -g -fs romans Arial -fs romanc Arial -f -o output.svg input.dwg
Return to “Chat”
