save and save as
tnj
save and save as
Post by tnj » Tue Sep 28, 2021 5:32 pm
When I try to save the drawing, or save as the program closes.
Re: save and save as
Post by Husky » Tue Sep 28, 2021 7:14 pm
Please try to toggle the file dialog under:
Edit > Application Preferences > File > Open/Save > Use system file dialog ...
... and try to save a drawing.
tnj
Post by tnj » Tue Sep 28, 2021 10:20 pm
That box was already checked. I tried unchecking it and applying the change save would not work, rechecked and applied that change and it still closes program when trying to save.
Post by Husky » Tue Sep 28, 2021 10:52 pm
Please,
- Indicate the operating system you are using and the version thereof (e.g. Windows 10 32bit, Windows 8.1 64bit, Ubuntu 14.2 64bit, macOS 10.12, etc.)
- Indicate the exact version of QCAD / QCAD/CAM you are using (see "Help" > "About" or "QCAD" > "About QCAD" or indicate the name of the file you have downloaded and installed)
- Attach original drawing files (DXF, DWG, ...) if appropriate
- If there is an error message, indicate the exact message or include a screenshot of the message
tnj
Post by tnj » Wed Sep 29, 2021 1:24 pm
windows 10 home 64 bit, Qcad is 3.26.4 just installed last week. No error message when dialog box to save pops up, it hesitates a few seconds then closes program.
Post by andrew » Wed Sep 29, 2021 3:29 pm
Does this happen when trying to save a new, empty drawing or with a particular drawing?
tnj
Post by tnj » Wed Sep 29, 2021 4:38 pm
It is the first drawing I did, and it auto saves it so I can reopen it when i reopen Qcad but it will not let me name it when I try to save, it just closes program. It is not empty.
Post by andrew » Wed Sep 29, 2021 4:44 pm
Does it also happen when trying to save an empty drawing?
Can you attach your drawing please?
tnj
Post by tnj » Wed Sep 29, 2021 5:47 pm
When program opened I did not ask it to open autosave file then tried to save empty drawing and it closed program. The only drawing I had was the autosaved one and now it is gone.
Post by andrew » Wed Sep 29, 2021 7:57 pm
There appears to be something wrong likely with the file dialog on your system in combination with Qt (the toolkit QCAD uses).
Do you have a chance to run QCAD on a different computer? If not, I'm happy to issue a refund as QCAD does not seem to work on your Windows setup.
tnj
Post by tnj » Wed Sep 29, 2021 10:29 pm
I have to go out of town for a few days, when I get back I will get an IT friend of mine to take a look at our chat line and see if he has any ideas before bailing out of the program altogether, thanks for the help.
Post by Husky » Wed Sep 29, 2021 11:10 pm
... I will get an IT friend of mine to take a look at our chat line and see if he has any ideas
I run QCAD since over 10 years mainly on Windows machines. All the way up from XP to 10 - QCAD was always working like a charm.
Basic rules for a proper installation are:
Use the correct installation packet for your OS,
Never mix different QCAD versions in the same subdirectory,
if the install msi isn't working for some reason use the zip archive,
follow the installation manual below https://qcad.org/en/documentation/insta ... er_Windows
follow the troubleshooting manual to reset QCAD below https://qcad.org/en/tutorial-resetting- ... on#Windows
Post by andrew » Thu Sep 30, 2021 7:08 am
Another thing worth looking into might be your virus protection. I can imagine that an overzealous or badly configured antivirus software might shut down a software like QCAD when it's trying to access the file system or certain directories. This should be configurable in the preferences of your antivirus or other protection software.
Here's a list of software I found that is known to interfere with the Windows file dialog:
  • AVAST Antivirus
  • Box Sync
  • Constant Guard (often used by Comcast customers)
  • Druva inSync
  • HP Trust Circles
  • PC Backup
  • Actual Multiple Monitors
  • UltraMon
If you use any of these or similar software, try disabling them or uninstalling them one by one to see which one is causing the issue.
tnj
Post by tnj » Thu Oct 14, 2021 9:54 pm
We tried all that you suggested with no luck. Please refund my fee I have deleted Qcad from my computer and will be using a different software. Thank you for trying to get it functional.
Post by andrew » Thu Oct 14, 2021 10:11 pm
Done.
Return to “Chat”
