label text invisible after new OS install
flanna
Post by flanna » Mon Aug 24, 2009 1:43 pm
I have been using QCad successfully for over a year with no problems. Recently I changed my hard disk and installed the operating system as per usual. I use OpenSuse 11.1 . This is the same os, and version, as I was using previously.
Now when I open an old QCad DXF file, all the labels and text are missing. When I make a new drawing it is not possible to add any labels or text.
What has gone wrong?
Post by andrew » Mon Aug 24, 2009 3:47 pm
flanna
Post by flanna » Mon Aug 24, 2009 5:52 pm
Thanks a lot Andrew. It's sorted!
Return to “Chat”
