Hola, soy ingeniero y he visto buenas referencias de Qcad, quiero probarlo. He bajado la última version May 13 2022 para Win10
Mi PC: RAM 32 Gb, 1Tb SSd 400 Mb libres, Intel 8va generación, OS Win 10 Professional 64 bits
Instalé la version trial professional, hice un par de ajustes en Preferencias luego, Aplicar, Reiniciar programa y no vuelve a cargar, queda congelado en la pantalla que adjunto. He esperado 3 minutos por si era una pantalla por tiempo para leerla.
He desinstalado, reiniciado PC y vuelta a instalar, pasa lo mismo. No carga. Mismo error.
Mi PC tiene Win 10 Prof. SO original actualizado a última versión. Ningún problema equivalente con otro problema
Necesito ayuda por favor.
Saludos
Hi, I am an engineer and I have seen good references of Qcad, I want to try it. I have downloaded the latest version May 13 2022 for Win10.
My PC: RAM 32 Gb, 1Tb SSd 400 Mb free, Intel 8th generation, OS Win 10 Professional 64 bits
I installed the trial professional version, made a couple of settings in Preferences then Apply, Restart program and it does not reload, it freezes on the screen I attached. I have waited 3 minutes in case it was a timed screen to read it.
I have uninstalled, restarted PC and reinstalled again, same thing happens. It does not load. Same error.
My PC has Win 10 Prof. Original OS updated to latest version. No equivalent problem with another problem
I need help please.
Regards
Qcad carga solo una pantalla de tienda.
- Qcad Frozen Screen.jpg (74.05 KiB) Viewed 2856 times
Re: Qcad carga solo una pantalla de tienda.
Please reset your configuration:
https://qcad.org/tutorial-resetting-the ... figuration
Most likely the user interface scaling factor was changed in a way that breaks on your system / installation.
