Hi i'm Xavi,
I need configurate my version of qcad(3.27.1.0), for default savings in *.dxf R12, i look at settings menu but i can't find this model of file!
Windows 10pro 64 bits!
R12_DXF favorite saving
- R12.jpg (163.57 KiB) Viewed 3812 times
Re: R12_DXF favorite saving
DXF R12 cannot save all the information in your drawing and should be considered a legacy export format only. DXF R12 will not save your custom properties or the real colors of entities. Splines are converted to polylines on export. Black entities and layers are saved as white.
I'd suggest to keep your drawing in a newer DXF or DWG file format and export to DXF R12 when needed, perhaps with file name mydrawing_r12.dxf or similar to distinguish the main data from the exports.
Yes i work with a cnc machine and i need remove Splines and colors, because cnc software crashes with this..... i use qcad, i xplde entites and saving with r12 is perfect for me....
There is no other solution??
Menu / File / "Save as" offers R12 dxf ...
