Cutting off lines after radiusing
n_spect_r
Post by n_spect_r » Wed Oct 05, 2022 11:20 am
This may have been covered, and I may not have a good description but could not find an answer. In older versions, If I drew a square, then radiused the corners, the straight lines went away, in the current version the straight lines remain, and I break out the segments. Curious if there is a setting to change this. Thanks.
Re: Cutting off lines after radiusing
Post by andrew » Wed Oct 05, 2022 11:25 am
Please refer to the user manual at:
https://qcad.org/doc/qcad/latest/refere ... c/RoundPro
Check "Trim" if you want to trim the entities automatically. If the option is disabled, the two corner entities will remain untouched.
Return to “Chat”
