Ajout module cône
Moderators: andrew, J-J
tukuyomi
Re: Ajout module cône
Post by tukuyomi » Mon Mar 04, 2019 6:24 pm
@andrew : sure thing ! :)
I did not think under which licence I could release it ... Actually, It was for my personal use and had no intention to release it :)
If ever you want to include it to Qcad, sure go ahead, but be sure to find very peaky customers :twisted: who'll probably want you to support more variations* , thickness, inside or outside development, ... At the very least, this could be a completely new software based on Qcad.
You can take my scripts as a reference, but if you have mathematical background, you might want to check this page to implement more clean functions :
- https://en.wikipedia.org/wiki/Ruled_sur ... c_geometry
- and the reference [5] (specifically chapter 10.2) on that same page
(*) So far, I can provide developments for
- circle-circle on same or differents plans angles (the above script)
- rectangle-circle ( https://i.imgur.com/Qzd8d4V.png ), rectangle-rectangle ( https://i.imgur.com/NfGkqgc.png ), based of the same logic.
-- Todo : variations like obround, ellipses and probably user-defined functions as a general case. Again, based on the generatrix logic, this is as simple as finding parametric equations of the shapes and apply a loop from 0 to 2*pi of generatrix calls, with small tweaks.
tukuyomi
Post by tukuyomi » Tue Mar 05, 2019 11:42 am
@gortex3D : J'ai rajouté un script pour faire des cônes simples ; tu le trouveras à cette addresse :
https://nikel.me/~jiefk/files/qcad/
_myCone.zip -> à décompresser dans le dossier scripts/_myScripts/
_myScripts.zip (contient aussi _myCone) -> décompresser dans le dossier scripts/
gortex3D
Post by gortex3D » Wed Mar 06, 2019 12:03 pm
Merci beaucoup pour ce nouveau module qui fonctionne au top. Juste une petite question. A quoi sert le champ croisement ? C'est la superposition pour fermer le cône en chaudronnerie ?
tukuyomi
Post by tukuyomi » Wed Mar 06, 2019 1:01 pm
Oui, c'est tout à fait ça ! D'ailleurs, sans indiscretion, dans quelle branche travailles-tu ?
gortex3D
Post by gortex3D » Wed Mar 06, 2019 1:10 pm
Merci beaucoup
Perso je travaille dans la transformation des élastomères, pu + un deuxième pôle maintenance avec quelques pièces mécaniques.
Et toi ?
tukuyomi
Post by tukuyomi » Wed Mar 06, 2019 2:23 pm
Pour ma part, je suis dans la métallurgie, dans la tôlerie pour être exact : fumisterie et pièces d'évacuation de fumées pour inserts, poëles ou cheminées.
Mon boss préfère payer pour des logiciels de dépliage/déroulage de pièces ; je préfère me les coder "maison" à mes heures perdues.
Et Qcad fournit tous les outils pour le faire :), même si je ne sais pas encore bien utiliser tous les outils de scripting à ma disposition.
En plus, ce faisant, j'entretiens le peu qui me reste des Maths de mes années Lycée :p
gortex3D
Post by gortex3D » Wed Mar 06, 2019 4:14 pm
En tout cas joli travail. J'ai supprimé sur les 2 scripts les propriété de couleurs et plus aucun soucis d'affichage. Ca s'affiche en blanc. C'est propre.
Perso je n'ai jamais appris a codé et je ne me rappelle plus comment tracer ces formes. Perso jusqu'à présent je les dessines mais en traçant mes droites pour trouver le points de convergence. Puis dessiner mes arc de cercle que je découpe en utilisant la longueur de la corde.
C'est archaïque pas super rapide mais ca marche.
La seul chose c'est que j'intègre dans mes calculs les épaisseurs matière car il m'arrive d'avoir des élastomères de 10mm d'épaisseur.
Post by andrew » Thu Mar 07, 2019 2:04 pm
Excellent, thanks! I will look into it as soon as time allows.
Yes, I'm fully aware of it. Users always want everything and now ;)
Papy Octet
Post by Papy Octet » Thu May 13, 2021 6:56 am
Bonjour.
Suite à un crash informatique, j'ai perdu pas mal de données dont le script dont il est question ici.
L'adresse donnée par tukuyomi ne fonctionne pas (404 not found).
Quelqu'un pourrait-il me dire où je peux récupérer ce script ?
Merci.
Debian 10 - Qcad-Prof 3.19.0.0
tukuyomi
Post by tukuyomi » Thu May 13, 2021 7:09 am
Je m'en occupe dans la matinée :)
EDIT : http://files.nikel.me/_myScripts_20210513.zip
Déplacer le dossier _myscripts à l'intérieur du dossier scripts de qcad !
( J'ai volontairement laissé plusieurs exemples d'utilisation pour donner des idées à ceux qui le veulent :) )
Papy Octet
Post by Papy Octet » Thu May 13, 2021 2:34 pm
Super.
Un tout grand MERCI pour ce partage.
A+
Return to “QCAD Professional”
