comma as decimal separator in cnc code
to get comma as decimal separator in cnc code, how to manage it, please?
1 TOOL DEF 01 L+0 R+0,05
2 TOOL CALL 01 Z S 2000
3 L X+100,000 Y+0,000 R0 F9998 M13
4 L Z-0,300 R0 F30 M
5 CC X+0,000 Y+0,000
6 C X-100,000 Y+0,000 DR+ R0 F30 M
7 CC X+0,000 Y+0,000
8 C X+100,000 Y+0,000 DR+ R0 F30 M
9 L Z+1,000 R0 F9999 M30
Re: comma as decimal separator in code constructor
Please elaborate. What do you mean by code constructor? Do you have an example or screenshot? Thanks
Re: comma as decimal separator in cnc code
is it possible to modify a CamExporter.js to get decimal comma?
CAM configuration dialog
- dialog.jpg (70.08 KiB) Viewed 39590 times
Yes, QCAD/CAM is configured through JavaScript. A comma for X values could for example be forced by overriding getXCode:peter wrote:is it possible to modify a CamExporter.js to get decimal comma?
Tnc145.prototype.getXCode = function(value) { var ret = GCode.prototype.getXCode.call(this, value); return ret.replace(".", ","); };I'm happy to assist you with creating a complete configuration for Tnc145 next week.
Thank you, very pleasant!
peter: You can now download the latest QCAD/CAM release 3.11.0 which contains a configuration called 'Tnc145'. This should be seen as a starting point for a configuration for your machine. Please test and get back to me with feedback, so I can make the necessary adjustments.
You can access your update using the direct link sent to you via e-mail after purchase or by following our detailed instructions at:
http://www.qcad.org/en/customer-area
adrew: Thank you, it looks already very fine, really!
nice
this.useComma = true;
this.trailingZeros = true;
1 TOOL DEF 01 L+0 R+0.05
3 L Z-0,300 R0 F30 M
4 X+22,478 Y+65,333 R0 F30 M -> 4 L X+22,478 Y+65,333 R0 F30 M
5 X+44,817 Y+76,059 R0 F30 M -> 5 L X+44,817 Y+76,059 R0 F30 M
6 CC X+22,829 Y+121,854
7 C X+72,183 Y+133,887 DR+ R0 F30 M
8 L X+51,279 Y+219,625 R0 F30 M
nice
Line one is part of the two line fixed header:
I've also attached the updated configuration file with R+0,05 for your reference.
this.writeLine("TOOL DEF 01 L+0 R+0.05"); this.writeLine("TOOL CALL 01 Z S 2000");You can simply adjust that to whatever exact contents you need for the first two lines.
- Tnc145.js
- Replaces file scripts/Cam/CamConfigurations/Tnc145.js
- (2.41 KiB) Downloaded 1099 times
andrew, I am sorry, I was wrong with my earlier statement concerning R+0.05 it is really not used with comma, TNC 145 accepts R+0.05
but in Line 4 and Line 5 of code example "L " as the leading letter is needed.
Just now I produced the following code with another well prepared and really working postprocessor:
1 TOOL DEF 01 L+ R+0.05
3 L X+0,000 Y+0,000 R0 F9998 M13
5 L X+22,478 Y+65,333 R0 F30 M
6 L X+44,817 Y+76,059 R0 F30 M
7 CC X+22,829 Y+121,854
8 C X+72,183 Y+133,887 DR+ R0 F30 M
9 L X+51,279 Y+219,625 R0 F30 M
10 L Z+1,000 R0 F9999 M30
it seems we are missing relevant content in line 3 of example above
- Test TNC.dxf
- (100.07 KiB) Downloaded 1087 times
I've attached another update with forced output of L for every linear move.
- Tnc145.js
- (2.48 KiB) Downloaded 1062 times
"L " for linear moves works fine now.
Line3 is still missed as output
3 L X+0,000 Y+0,000 R0 F9999 M13
- TNC145 dev.JPG (120.61 KiB) Viewed 39367 times
I've attached an update.
Changes:
- Changed first line of header from "TOOL DEF 01 L+0 R+0,05" to "TOOL DEF 01 L+ R+0,05"
- Force first move, even if it's to 0,0
Changes:
- Tnc145.js
- (2.73 KiB) Downloaded 1072 times
andrew, it works fine, thank you for your help, absolutely great job!
If we need your help for a other untested sequence, I would like to come back here and ask you, please?
Sure, no problem. Be sure to also look at the file Tnc145.js. Many things can be adjusted easily, even with limited JavaScript or QCAD/CAM expertise.
next days we will test this on MIKRON TNC145, thank you so far!
after moving to a next contour happens a little error
1 TOOL DEF 01 L+ R+0,05
3 L X+1,272 Y+0,400 R0 F9999 M13
5 L X+0,272 R0 F30 M
6 L Y-0,533 R0 F30 M
7 CC X+0,737 Y-1,136
8 C X+0,806 Y-0,378 DR- R0 F30 M
9 CC X+0,745 Y-1,018
10 C X+1,206 Y-1,467 DR- R0 F30 M
11 CC X+0,777 Y-1,046
12 C X+0,250 Y-1,333 DR- R0 F30 M
13 L Z+1,000 R0 F9999 M13 F30
14 L X-1,350 R0 F9999 M13
15 CC X-0,814 Y-1,027 <<<<<<<<<<<<<<<<
16 L Z-0,300 R0 F30 M <<<<<<<<<<<<<<<<
17 C X-0,817 Y-1,644 DR+ R0 F30 M
18 CC X-0,817 Y-1,122
19 C X-0,817 Y-0,600 DR+ R0 F30 M
20 CC X-0,817 Y-0,078
21 C X-0,817 Y+0,444 DR+ R0 F30 M
22 CC X-0,813 Y-0,139
23 C X-1,350 Y+0,089 DR+ R0 F30 M
24 L Z+1,000 R0 F9999 M30
- 35.JPG (40.88 KiB) Viewed 39330 times
