PDF Export
PDF Export
I wants to save drawings in PDF and dwg file. For this QCad Pro needs to buy or free trial version is enough..?
Re: PDF Upload
You can save a drawing with the free edition as a pdf. Unfortunately dwg is only with the Pro possible.kamuthi wrote:I wants to save drawings in PDF and dwg file. For this QCad Pro needs to buy or free trial version is enough..?
QCAD Features comparison Free / Pro
http://www.qcad.org/en/qcad-documentation/qcad-features
Re: PDF Upload
This PRO is one time buy or yearly renewal..?
Re: PDF Upload
Yes - one time and you can use it forever.kamuthi wrote:This PRO is one time buy or yearly renewal..?
With the "one time" buy you will also get one year free updates - no additional cost!
http://www.ribbonsoft.com/shop/product. ... roduct=181
Re: PDF Upload
whats the difference between QCAD Professional & QCAD/CAM: QCAD Pro + CAM Add-on
Re: PDF Upload
QCAD Pro is used to draw CAD drawings.kamuthi wrote:whats the difference between QCAD Professional & QCAD/CAM: QCAD Pro + CAM Add-on
The CAD/CAM Version combines the CAD (Computer Aided Design) drawing task with the CAM (Computer-Aided Manufacturing) part for further processing like CNC Maschines. The CAM add-on will produce the code to control/operate processing machines like CNC (Computer Numerical Contro) milling machines etc etc
Re: PDF Upload
Just made a simple drawing and exported to PDF, but pdf file looks empty.
what may be the reason for this..?
Re: PDF Upload
Please refer to our printing and PDF export tutorial at:
http://qcad.org/rsforum/viewtopic.php?f=47&t=3317
Re: PDF Export
can we select particular portion of the drawing and export as pdf..?
Re: PDF Export
You can use the "Print Current View" tool for this purpose. If that isn't what you are looking for please bring us a concrete example. Thanks.
- Registered Member
Re: PDF Export
You may find this feature through the "Print" option. And that's what I exactly like about QCAD - the most part of the software related to this one still has no way how you're able to export your piece to PDF directly without additional tools. For example, FreeCAD has so, but when I was using it all the documents become corrupted and messy looking when I saved them as PDF, so I fixed them manually via this tool pdffiller DOT com It's a more business-papers-related thing, but works well in order to fix some poor printing issues
