Hello
How can I create polylines?
(I'm currently looking at scripts/Draw/Polyline/DrawPolyline/DrawPolyline.js)
- Full Member
- Location: http://creativitainformaticart.altervista.org
Re: How can I create polylines?
You might want to include "scripts/simple_create.js" and use the simplified API of QCAD:
For example:
addPolyline([ [ 100 , 0 ], [ 20 , -10 , 1 ], [ 0 , 40 , 0 , true ], [ -20 , -10 , 1 , true ] ]);
The full code (without using the simple API) would be:
For example:
// doc is your RDocument
// di is your RDocumentInterface
var pl = new RPolylineEntity(doc, new RPolylineData());
pl.appendVertex(new RVector(x,y));
var op = new RAddObjectOperation(pl);
di.applyOperation(op);
- Full Member
I saw to close the polyline with "scripts / simple_create.js",
But to close the polyline with the full code?
Thank you
Thank you
Please try to be more specific: what data or objects do you have and what do you want to achieve.
For example:
I have an RPolyline object representing a polyline that is open and wish to change it into a polyline that is closed.
Or:
I have a list of vectors and wish to create a closed polyline entity from them and add that to the drawing.
Or:
My drawing contains an open polyline entity which should be converted into a closed polyline entity. I know the ID of the polyline entity.
These are all quite different situations requiring different approaches.
For example:
Or:
Or:
- Full Member
Well, maybe I do not need it, I've seen that fills can even be done without closing a polyline made of straight lines
