Custom property filter
dfriasb
Senior Member
Post by dfriasb » Tue Apr 11, 2017 11:19 am
Hello all,
Is it possible to filter entities by Custom Properties? (I mean the ones user can add at the end of the Properties Toolbar)
If not, I guess it is possible using some script, is it?
Thank you. Best regards,
David
David Frías Barranco | architect
[email protected] | davidfriasarquitecto.es
Re: Custom property filter
Post by andrew » Thu Apr 13, 2017 8:37 am
Hello, can you please ellaborate? Filter in what sense? For selection (as in View > Selection Filter)? Thanks.
dfriasb
Senior Member
Post by dfriasb » Fri Jun 16, 2017 3:12 pm
Yes, I mean using View > Selection filter. I don't see any "Custom Property" option in the Selection Filter "Property" menu, so I guess it is not possible right now, at least without scripting specific command to do that.
Regards, David.
Screenshot from 2017-06-16 16-09-50.png (9.72 KiB) Viewed 8552 times
Post by andrew » Wed Jun 21, 2017 8:38 am
dfriasb wrote:I don't see any "Custom Property" option in the Selection Filter "Property" menu, so I guess it is not possible right now, at least without scripting specific command to do that.
Yes, that's correct.
I've added a feature request at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1596
dfriasb
Senior Member
Post by dfriasb » Wed Jun 21, 2017 9:31 am
Thanks again Andrew!
