Dimension label font in free version
marzof
Post by marzof » Thu Aug 06, 2015 4:50 pm
I noticed a weird behavior of dimensions fonts in the free version of QCAD.
When I draw some dimension, the label is extremely clear and simple like that in the attached image (dim1.png).
If I change something in the Dimension dialog (from Edit->Drawing Preferences->Dimension Settings) the labels font in the drawing changes to a different font (in my case it uses "DejaVu Sans" as you can see in the second image, dim2.png).
This happens even if I make no effective change like, for instance, if I disable and re-enable the "Keep proportions" checkbox.
I noticed that it's possible to change the label font, just, replacing it in the dxf file (I know that the Pro version allows to change the font in the dedicated dialog).
The strange thing is that if I re-open the file, all the dimensions labels are back to the clear initial font and I need to do the trick in the dimension dialog to reset all the label with the font I've chosen.
Is it a bug?
Initial label font
Label after changes in dimension dialog
marzof
Re: Dimension label font in free version
Post by marzof » Thu Aug 06, 2015 6:23 pm
I forgot to say that I run QCAD 3.9.8 on Ubuntu 14.04 (but I noticed the same behavior on previous versions of QCAD and on Windows 7).
marzof
Post by marzof » Sun Aug 23, 2015 5:56 pm
Did anybody encounter this bug?
Or it affects just my two computers?
Thanks for your reply
djorlando24
Post by djorlando24 » Tue Apr 11, 2017 3:58 am
I have seen very strange behavior with unexpected font changes after updating my MacOS QCad community edition to the latest version as well. Now all my dimensions render with this very ugly bold wide spaced font and I can't seem to change it! Anyone else having this problem? I tried removing all preferences and wiping & reinstalling the application, with no effect.
Dan.
strange new font on QCad for MacOS
new font.png (47.3 KiB) Viewed 19506 times
Post by andrew » Thu Apr 13, 2017 8:55 am
For all support requests, please:
- indicate the exact version of QCAD you are using (see Help > About or QCAD > About QCAD)
- attach original drawing files (DXF, DWG, ...) if appropriate
lphilpot
Senior Member
Post by lphilpot » Sun Nov 05, 2017 12:53 am
marzof wrote:Did anybody encounter this bug?
Two years later, but yes - I see it, too with QCAD CE 3.18.1 x64 (on Xubuntu 16.04 64-bit). Technically, I guess it's a bug since it's "spontaneous" behavior, but actually the font that shows up after applying drawing preferences is preferable to me. I wish it would "stick" full time.
Len
QCAD Pro
Post by Husky » Sun Nov 05, 2017 1:20 am
lphilpot wrote:I wish it would "stick" full time.
It sticks pretty good in the Pro because there is a setting in Application/Drawing Preferences which takes care of the Dim Font ...
lphilpot
Senior Member
Post by lphilpot » Sun Nov 05, 2017 1:25 am
Don't torture me, I'm waiting on Christmas, man.... :mrgreen:
Len
QCAD Pro
Post by Husky » Sun Nov 05, 2017 1:45 am
lphilpot wrote:Don't torture me, I'm waiting on Christmas, man.... :mrgreen:
That wasn't my intention. 8) Ok, to make it not harder than necessary I'll keep my mouth shut and don't tell you that it is less than 50 days until Christmas. But only if we talk about next Christmas and not about the Christmas in 2018 .... :lol:
