QCAD not starting up
todayscomplete
Post by todayscomplete » Tue Jan 16, 2018 1:38 am
I have an issue with QCAD not starting up when opening a file or even opening the application. Previously had the trial version for a couple of years recently upgraded to professional version November 2017 worked fine for rest of the year. Tried using yesterday and simply wont start up. have tried uninstalling/re-installing, deleting all QCAD files starting fresh downloading again, tried trial version again to no avail nothing will work. Please help need this software for business use.
Re: QCAD not starting up
Post by Husky » Tue Jan 16, 2018 2:39 am
Hi todayscomplete - welcome to the QCAD Forum.
todayscomplete wrote: have tried uninstalling/re-installing, deleting all QCAD files starting fresh downloading again, tried trial version again to no avail nothing will work. Please help need this software for business use.
You are on which OS? Did you reset QCAD?
http://www.qcad.org/en/qcad-documentati ... leshooting
If not please reset QCAD but first make a backup of the QCAD3.ini or QCAD3.conf. Very important - don"t mix QCAD installations. Use always an empty or new folder.
Return to “Chat”
