Unable to print in Qcad. (Solved).
Jim0000
Post by Jim0000 » Tue Jan 30, 2018 10:02 am
I am unable to print a drawing in Qcad.
I am using Qcad version 3.16.4
Linux Mint 17.3 KDE operating system.
I have read several threads about this problem, so far have not found a solution that solves my problem.
Must be something very simple.
Assistance would be much appreciated.
Re: Unable to print in Qcad.
Post by andrew » Tue Jan 30, 2018 11:04 am
Please read through this thread about printing first:
viewtopic.php?f=47&t=3317
If you cannot solve your problem, please:
- attach original drawing files (DXF, DWG, ...)
- include screenshots if appropriate
- if there is an error message, indicate the exact message or include a screenshot of the message
Also please be much more specific. What exactly happens if you attempt to print? Nothing? Does the print dialog show up? Is an empty paper produced? ...?
Jim0000
Post by Jim0000 » Wed Jan 31, 2018 2:51 am
Thanks for the reply Andrew.
sorry about limited information. I will follow your instructions and post again.
Jim0000
Post by Jim0000 » Fri Feb 09, 2018 12:46 am
Ok Andrew, I have read through the thread on printing and checked every point.
When I go to print this drawing (see attachment), the paper goes through the printer and all I get is a straight line across the paper.
Screenshots attached.
Please advise what further information I should provide.
Thanks,
Jim.
Drawing unit.png (58.18 KiB) Viewed 2792 times
Forum submission.png (180.86 KiB) Viewed 2792 times
Elliptical tip panel.dxf
(97.17 KiB) Downloaded 92 times
Post by andrew » Fri Feb 09, 2018 2:15 pm
As you can see in your last screenshot, the paper (white) is nowhere to be seen. It's actually somewhere in the lower left corner:
Screen Shot 2018-02-09 at 13.11.38.png (408.67 KiB) Viewed 2580 times
Please read again steps 8, 9 and 10 from:
Screen Shot 2018-02-09 at 13.13.24.png (393.27 KiB) Viewed 2580 times
Jim0000
Post by Jim0000 » Fri Feb 09, 2018 11:52 pm
Thanks Andrew. I got it to work. The two (apparently) conflicting scale entries is what was putting me off.
All good now.
I'll mark this thread as solved now.
