With qcad pro, if I do export bitmap with meter unit, shapes are not shown (see attached picture : meterUnit.bmp).
If I do with with milimeter, it exported well (see attached picture : milimeterUnit.bmp).
Is this a bug, or I need to do something further for exporting with meter unit ?
Export bitmap with meter unit
- milimeterUnit.bmp (900.05 KiB) Viewed 6332 times
- meterUnit.bmp (900.05 KiB) Viewed 6332 times
Re: Export bitmap with meter unit
Please attach the original drawing file (DXF, DWG, ...) and indicate what parameters you are using for the export.
For all support requests, please:
- indicate the operating system you are using and the version thereof
- indicate the exact version of QCAD you are using (see Help > About or QCAD > About QCAD)
- indicate the QCAD Edition you are using (QCAD Professional, QCAD Trial-Version, QCAD Community Edition)
- attach original drawing files (DXF, DWG, ...) if appropriate
- attach exported files (SVG, PNG, PDF, ...) if appropriate
- include screenshots if appropriate
- if there is an error message, indicate the exact message or include a screenshot of the message
.dxf is attached, I use defaults properties (see picture attached defaultProperties.PNG).
Operating system : windows
QCAD edition : Professional Professional
QCAD version : 3.19.2.0
- settingsQCAD.PNG (99.17 KiB) Viewed 6328 times
- defaultProperties.PNG (41.33 KiB) Viewed 6328 times
- 11.bmp (900.05 KiB) Viewed 6328 times
- 11.dxf
- (100.21 KiB) Downloaded 458 times
Thanks for the file.
I can confirm that these lines are so thin (0.25mm, less than a pixel) that they become invisible in the bitmap output. This is not intended and will be corrected for the next release by exporting very thin lines as one pixel wide:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1725
