Bug: Different angular dimension in viewport and model
johan162
Post by johan162 » Mon Jul 30, 2018 9:53 am
I have a model where one of the details is as following:
Screen Shot 2018-07-30 at 10.30.32.png (43.4 KiB) Viewed 5124 times
However, when I create a viewport and display the part in the the layout the angular measurement is screwed up (sorry no better technical term ...)
Screen Shot 2018-07-30 at 10.31.06.png (45.8 KiB) Viewed 5124 times
Having done some experiments with some different angles it always seems like the layout angle is always +31 degrees more (up to rounding).
In the model it should be noted that the part displayed is a detail copied with a different scale as to Zoom in on a detail in order to put dimensions on it. It was created by copying a part of the model and pasting it back in the model but with 3x zoom.
I have also included the full .dxf file in the hope that it helps you both reproduce and fix this issue
buggy_angular_in_viewport.dxf
(203.48 KiB) Downloaded 507 times
Re: Bug: Different angular dimension in viewport and model
Post by Husky » Mon Jul 30, 2018 4:31 pm
I'm able to reproduce the issue.
I don't see that pattern - in my test the changes are floating regarding to the new position in Paper_Space.
Best change to get that fixed would be to file a Bugreport. Please use http://www.ribbonsoft.com/bugtracker
johan162
Post by johan162 » Mon Jul 30, 2018 4:56 pm
Filed as: "FS#1792 - Different angular dimension in viewport and model"
You are also right about the +31 degrees I hypothesized. It seems to change randomly when you remove and re-add the angular dimension.
An interesting bug ...
