Hello
Im draving alot of drawing and it saved in my CNC on -> xxx.bdf <- format is any chance for future to open and save and open template on this BDF format . Thank you Ladislav
BDF CAD file format
Re: BDF CAD file format
Unlikely. I've never heard of that format before... If you can provide details or an example file, I can probably tell you more.
zadychladislav
Wow thank you so much for so faster answare
In attachment are two files one is BDF file and one is DXF file both are the same drawing.
For CNC WE USE BDF FILE CNC ARE ITALY PRODUCE NAME BIMATECH OR INTEAC FOR STONE & GLASS PROCESING
Both are in one zip.file becouse BDF I cant send alone by attachment.
REGARDS Ladislav
REGARDS Ladislav
- importa DXF & BDF.7z
- Bdf & Dxf File in zip
- (3.25 KiB) Downloaded 2070 times
Unfortunately, this looks like a binary format (not human readable). This means that this cannot be supported for import or export in any way.
zadychladislav
Im using TechnoCad software and im opening easy check attachments
- 20181108_152208-744x744.jpg (155.09 KiB) Viewed 93613 times
- 20181108_152248-744x744.jpg (134.08 KiB) Viewed 93613 times
Sorry that I have not better news. Your best option is probably to find a converter from BDF to DXF or DWG or to find a CAD software that can import BDF and export DXF (perhaps the TechnoCad you are using can export to DXF).
