[solved] Linetype issue
It is a small issue but very annoying when i click on a line it appears to be a dotted line attached is a dxf
- Test.dxf
- (99.77 KiB) Downloaded 665 times
Re: Linetype issue
Hello Nate, welcome.
Most likely the line type is set to something dashed!
Best practice is to set up your own layers and set the line weight, line type and colour to what works for you!
Re: Linetype issue
i had made sure it is set to continuous i have a feeling it has something to do with the application preferences menu ????
Re: Linetype issue
Hi - I assume you are right
The dxf shows nothing unusual to me - please post a screenshot with a selected entity like this one. Thanks.
Re: Linetype issue
any help how to fix this??
- Capture2.JPG (143.22 KiB) Viewed 10647 times
Re: Linetype issue
Looks like a secondary selection color is enabled under:
Edit > Application Preferences > Graphics View > Colors > Use secondary selection color
Re: Linetype issue
Perfect Thank you Very much
