Dear all,
I just installed QCAD 3.22.0 in an Ubuntu 18.04 machine an it's not looking as nice as before, in my opinion. Some check boxes are also not visible, as you can see in the screenshot attached here. Default theme is looking fine like before.
Thanks! David.
Dark Theme in Ubuntu
- dfriasb
- Senior Member
- Screenshot from 2019-03-08 15-43-00.png (139.32 KiB) Viewed 2439 times
- Screenshot from 2019-03-08 15-34-33.png (55.03 KiB) Viewed 2441 times
Re: Dark Theme in Ubuntu
This needs a lot more work or possibly a separate theme under Linux and is currently optimized for macOS / Windows:
- dfriasb
- Senior Member
Ok! No problem, meanwhile I'm using default's. Thanks a lot!
For what it's worth, I recently inline-upgraded my Xubuntu 16.04 desktop to 18.04.2. I'm running the Greybird desktop theme and the Xfce 4.6 Default window manager theme, along with the QCAD dark theme. So far, so good as far as QCAD (3.21.3.0) is concerned:
QCAD is build on QT, which IME seems to be more resilient to environment changes than GTK. I've had to select my desktop theme carefully, since GTK3 (ick) no longer plays nicely with many older GTK apps and there can be huge UI artifacts with many older themes.
Len
QCAD Pro on Xubuntu Linux (usually)
- dfriasb
- Senior Member
Thanks lphilpot. My problems with dark theme started on 3.22 QCAD Pro version. Version 3.21 was looking good on my Ubuntu 18.04 machine. Did you try last version of QCAD? Dark theme was modified on it: https://qcad.org/en/changelog
No I've not tried that version. My pro upgrade entitlement expired in December and I've not upgraded since. However now that you mention it, I think I tried a newer snapshot late last year with the same results you're getting. So I went back to my version.
Len
