Just for fun - QCAD drawing challenge !!!
Re: Just for fun - QCAD drawing challenge !!!
Post by Husky » Sat Nov 18, 2017 10:24 pm
This machine was one step in the production chain for cheese manufacturing and it purpose was to drain, pre-press and cut cheese.
Completely built out of Stainless steel, length 25' - 30', width approx. 8' and a height of approx. 15'.
Post by Husky » Sat Nov 18, 2017 10:27 pm
Post by andrew » Fri Dec 01, 2017 3:00 pm
slyde
Post by slyde » Sat Dec 02, 2017 9:44 am
Mine's kind of off, but it was fun trying. Thanks for the challenge :-)
Masonry drawing challenge.dxf
(433.89 KiB) Downloaded 145 times
Look! It's a bird. No! It's a plane! NO! It's QCAD hotkeys...faster than a possum falling out of a tree!!
OS: Linux Mint 18.3 Sylvia [64-bit]
QCAD Pro 3.19.2.0 [64-bit]
Post by Husky » Tue Apr 09, 2019 9:05 pm
Hi guys - somebody here who can untangle my brain ...... :shock: :shock: :shock:
I need a accurat solution and I'm more in a guessing mode than in a knowing mode.
I need to put small circles around a bigger circle. The small circles have to touch each other - no gabs between them. I know the diameter of the small circles and how many have to be placed. I don't know the diameter of the big circle. How can I figure that out?
The result should look like this - but more accurate ..... e_surprised
Values:
Diameter small circle = 6.35
Quantity = 52
Big circle = ???
I've the feeling MS Excel etc. should be the solution to the problem but Google and co. showed me always ad the end of all results " ... not absolute accurate". :twisted:
lphilpot
Post by lphilpot » Tue Apr 09, 2019 9:19 pm
So would this work...
Imagine a larger construction circle centered on the big circle that runs through the center of each small circle. You can calculate its circumference (c = 52 * 6.35) and therefore its diameter (d = c / pi). Then reduce the diameter by 6.35 to make it coincide with the inside of each small circle, instead of their centers. Shouldn't that be the circle you want?
Would that work? I'm just doing this in my head, as if it were a programming exercise (and I'm no mathemetician!). :-)
Len
QCAD Pro on Xubuntu Linux (usually)
Post by andrew » Tue Apr 09, 2019 9:27 pm
To construct this with QCAD:
- Draw 2 rays with angle 360/n = 360/52.
- Each of these rays will be tangential to one of the small circles.
- Use Draw > Circle > 2 Points and Radius to draw one of the small circles with radius = 6.35/2.
- With a simple auxiliary line (red) you can now construct the large circle.
Screen Shot 2019-04-09 at 21.25.15.png (27.93 KiB) Viewed 1649 times
Post by Husky » Tue Apr 09, 2019 9:52 pm
@lphilpot
Thank you for the try - but that isn't accurate enough. :wink:
@Andrew
Seriously? That easy? My brain was boiling and I haven't seen the obvious thing to do. THANK you! :D
lphilpot
Post by lphilpot » Tue Apr 09, 2019 9:57 pm
Yeah, after I thought about it a bit more, I realized the construction "circle" in my method was actually a 52-sided polygon, not a circle at all.
Len
Post by Husky » Tue Apr 09, 2019 11:15 pm
Don't worry about that. I was there too. :lol: :lol: :lol:
Panchdara
Post by Panchdara » Thu Apr 11, 2019 11:52 am
So embarrassed.... had to remove my incorrect attempt :oops: :oops: :oops:
How about this??? (Fixed intersection probs)
Circles.dxf
(115.05 KiB) Downloaded 93 times
Win 10, QCAD 3.23
Return to “Chat”
