Cutting objects
jhurley
Cutting objects
Post by jhurley » Sat May 18, 2019 4:22 am
I was wondering if there was a tool whereas you could cut shape at a specific spot? Similar to the cut/scissors tool in illustrator etc?
Re: Cutting objects
Post by Husky » Sat May 18, 2019 6:06 am
QCAD has a few cutting tools but of course not like Illustrator. QCAD is a CAD program - Illustrator is a graphic design program.
Maybe you could elaborate a bit more what you like to do with QCAD and we will see if it has the proper tools for that. :wink:
jhurley
Re: Cutting objects
Post by jhurley » Sun May 19, 2019 9:44 am
Yeah Illustrator does have an export to DXF option, just giving Q-cad ago as a teaching tool. The example would be how to do cut a 1/4 of a circle?
Re: Cutting objects
Post by Husky » Sun May 19, 2019 5:19 pm
You could use for that the "Clip to Rectangle" tool in QCAD ...
... but I don't believe that your example will answer the question .... :wink:
Return to “Chat”
