cycling through vertices in properties dialog - make nodes highlight?
Krischu
Post by Krischu » Thu Sep 26, 2019 11:11 am
When cycling through the vertices in of a POLYGON, is it possible to hilite the respective node in the drawing? Or show their numbers (index)?
Solved by Husky 4 posts down.
Christoph
Re: cycling through vertices in properties dialog - make nodes highlight?
Post by CVH » Thu Sep 26, 2019 2:48 pm
A faint circle and cross will hop.
Krischu
Post by Krischu » Fri Sep 27, 2019 9:58 am
Indeed, very faint. I didn't recognize it in the first place :). And it disappears once the cursor has moved away from the vertex listbox into the drawing area and it doesn't come back once the cursor is moved back into the property editor. Is it possible to increase visibility of that crosshair marker?
Christoph
Post by CVH » Fri Sep 27, 2019 10:08 am
Ask the creator.
Probably yes or enter a feature request.
Tryout AppPrefs/Graphics View/Colors.
Post by Husky » Fri Sep 27, 2019 7:06 pm
Yes.
Krischu
Post by Krischu » Sat Sep 28, 2019 7:56 am
Thanks. How again do I mark a thread as solved and give the author my compliments? Is there a button? I didn't find it.
Christoph
