Hi, I received a DXF but I need to separate layers to work in another application.
I need to modify the arq2.DXF file to be separated and colored layers like the arq1.dxf file
Could someone help me do this in QGIS?
Thanks a lot.
URGENT: to separate layers in Dwg / dxf
- Registered Member
- arq2.png (124.26 KiB) Viewed 3375 times
- arq1.png (127.99 KiB) Viewed 3375 times
Re: URGENT: to separate layers in Dwg / dxf
It's hard for me to believe they used only two layer for arq2.dxf. How did you load it into QCAD Trial? Menu File / Open or import? If you imported the file try instead just to open it
Probably not - this is the QCAD Forum.
Depends if Z is used.
If so, you could re-seperate by altitude in Z.
Without a file we can't even know that.
Your welcome to post both files.
