I have some issues in cleaning a dxf file I produce from projections of a sketchup model.
Having several stacked lines I use the detect duplicate command, but when I choose to delete the detected duplicates all of the lines are deleted and not only the redundant ones.
I attach one of the files I'm having troubles with.
remove duplicate lines
- Registered Member
- casa_salute_fronte_e.dxf
- (451.02 KiB) Downloaded 91 times
Re: remove duplicate lines
I assume the issue is based on the size of your drawing. It is very tiny with unusual short line entities.
Roof upper left side:
To clean that up effectively you have to adjust the "Distance Tolerance" in the "Detect Duplicate" Option bar or scale the drawing to a more reasonable size.
The function 'Detect Duplicate' will find duplicates
governed by the given tolerances as far as they:
when they only overlap partially they are not considered as a duplicate.
See example dxf.
Above 0.00045 tolerance most parallel lines of the rooftop are considered as duplicates.
As they are only spaced 0.000085 / 0.000338 / ....
I saw some did protude a little.
With a few simple selects I could isolate some on 5 separete layers.
From what was left I have put the duplicates found apart in layer 6.
Before deleting any it is better to move them to a temporary layer (eg. Trashcan).
It not looking great.
I afraid there is now easy solution.
Revised file attached
- are almost the same
are almost at the the same position
have almost the same angle
See example dxf.
- casa_salute_fronte_e_rev.dxf
- (501.39 KiB) Downloaded 79 times
- Not duplicates.dxf
- (99.39 KiB) Downloaded 82 times
