Free Hatch Patterns
Re: Free Hatch Patterns
Post by John Hyslop » Sun Dec 29, 2019 11:17 pm
BARBWIRE Hatch Pattern, Handy for Architechs Adding Wire to Fences
BARBWIRE - Metric and Imperial.zip
(2.5 KiB) Downloaded 1633 times
Post by John Hyslop » Mon Dec 30, 2019 12:47 am
WIRE-FENCE Hatch Pattern
WIRE-FENCE - Metric and Imperial.zip
(1.13 KiB) Downloaded 1690 times
Post by John Hyslop » Mon Dec 30, 2019 12:59 am
An example of the previous Hatch Patterns in use...fill borders on Layer Invisible ...
Post by John Hyslop » Mon Dec 30, 2019 3:23 am
LOOPLINKS Hatch Pattern..This Pattern Has been Removed and Will be updated ASAP
New Updated Pattern now on Page 4 of this topic
Post by John Hyslop » Tue Dec 31, 2019 1:49 am
Hi Andrew
I noticed in Qcad 3.24 that small lines are rendered as points, this is good but I had to redo LATTICE-02.PAT
manually as it had a Zero on the end of 2 lines, I've commented in PAT files where... if the current Pattern
File is Exploded it shows these points and sometimes even if not exploded also shows them slightly.... anyway
here are the updated Files please just write over the older ones..see what I mean by points in image below..
Fixed Lattice-02 Pattern.jpg (16.69 KiB) Viewed 35192 times
Lattice-02 - Points.jpg (19.59 KiB) Viewed 35193 times
LATTICE-02 - Imperial and Metric Updated.zip
(595 Bytes) Downloaded 1660 times
Post by John Hyslop » Sun Jan 05, 2020 3:02 am
Hi All
I'm Currently Testing out this tool "Tile2Hatch tool © CVH 2020" It seems to work flawlessly even at testing stage so
I'm posting all my patterns now using this tool as the AutoCad one has a lot of limitations... all header files will
contain this message to credit CVH on his amazing work on this tool that runs in Qcad :-)
*HATCHNAME
;By John Hyslop, Tile2Hatch tool © CVH 2020
;Developed in inch as imperial QCAD3 pattern
AND
*HATCHNAME
;Developed in mm as metric QCAD3 pattern
Post by John Hyslop » Sun Jan 05, 2020 3:06 am
Files Attached In Imperial and Metric
BUBBLES-01,BUBBLES-02, LEAF-01 and LEAF-02..
Using Tool Developed by CVH "Tile2Hatch tool © CVH 2020"
New Updated Patterns now on Page 4 of this topic
Bubbles-01 and 02.jpg (84.55 KiB) Viewed 35107 times
Leaf -01 and -02 Patterns.jpg (120.3 KiB) Viewed 35113 times
Post by John Hyslop » Mon Jan 06, 2020 6:13 am
HATCH-DOTS and HATCH-SQRS in Metric and Imperial
HATCH-DOTS - HATCH-SQRS - Metric and Imperial.zip
(1.65 KiB) Downloaded 1625 times
Post by John Hyslop » Tue Jan 07, 2020 6:28 am
Optimised Patterns Please replace older patterns with these ones
Patterns Will be updated ASAP
SCAFFOLD PATTERN HAS BEEN UPDATED, PLEASE SEE POST DATED 11/01/20
SQUIGGLE-01 & SQUIGGLE-02 Have been updated and can be found on page 4 of this topic
Optimised Patterns.jpg (206.8 KiB) Viewed 35057 times
Post by John Hyslop » Fri Jan 10, 2020 9:50 am
LEAF-03 PATTERN
Pattern Will be updated ASAP
Post by John Hyslop » Sat Jan 11, 2020 2:10 am
LATTICE-07 Pattern [ Similar to LATTICE-02, but woven instead of overlapped ]
You Can Also Create This With My Free Basic Hatch Tool, That Can Be Downloaded Using The Link Below..
https://www.qcad.org/rsforum/viewtopic. ... =15#p33566
LATTICE-07 - Metric and Imperial.zip
(666 Bytes) Downloaded 1630 times
Post by John Hyslop » Sat Jan 11, 2020 3:20 am
WEAVING Pattern
WARNING This uses a lot of resources use wisely ;-)
Post by John Hyslop » Sat Jan 11, 2020 7:13 am
UPDATE TO SCAFFOLD PATTERN
DUPLICATE LINE REMOVED - 11-01-20
SCAFFOLD - Metric and Imperial.zip
(1.38 KiB) Downloaded 1712 times
Post by John Hyslop » Fri Jan 24, 2020 5:21 am
Hi All
As you are all aware CVH discovered that some hatch patterns when hatched far away from the drawings X Y Origin start to lose accuracy , this is due to the limitation of the number of decimal points used to calculate entity positions at that distance. Although it's not the norm to hatch at such distances, we have come up with a workaround if needed, simply click on the pattern that has lost it's definition and reset the hatch origin... see screenshot below. I will be reinstating the patterns I removed recently as we now know what is causing this...
The Installed AR-CONC.PAT does exactly the same thing and that's been around for years
Drifting Hatch Patterns.jpg (158.11 KiB) Viewed 34702 times
Post by John Hyslop » Fri Jan 24, 2020 5:34 am
New Updated Patterns now on Page 4 of this topic, The QCAD-LOGO was kindly fixed up by CVH , he edited 1 line of the code that was making 1 side of the pencil shift...dramatically [/size][/b]
