I expected a weird behaviour on QCAD vs Autodesk. I have a DWG file and I uploaded it on Autodesk online, on ontodesk we can see diferents models and sheet (img1) but when I open the file with QCAD I have only the plan. Why ?
Can we export the same data (sheet + plan) ?
If anyone has the answer I would be thankful
Debian 10
QCAD version 3.22.1
The ZIP file contains many screenshot and the DWG file
If you want to check on autodesk: https://viewer.autodesk.com/designviews
[SOLVED] dwg2pdf: export sheets (layouts, paper spaces)
- dwgenplusieurspages.zip
- (2.44 MiB) Downloaded 556 times
- Capture d’écran du 2020-06-09 09-25-16.png (439.44 KiB) Viewed 6237 times
Re: How rto show sheet and plan
You can find the "Sheets" under View > Blocklist. Sheets are also called "layout blocks" and are indeed special blocks.
Thanks but I would like to export it with command lide so I used this:
/[PATH]/dwg2pdf -platform offscreen -c -a -f -block=RDC,Model,SS -outfile=pdfOut.pdf dwg9Juin.dwg
it works but I want to use regex instead of name because I don't know all the time the name, how can I do that ? with -block=/.*/ or /*/ there is no result
Do you have any idea ?
Please do mention these details, so we can help efficiently, thanks.I would like to export it with command lide
The regular expression can be specified as:
-block=".*"
Re: dwg2pdf: export sheets (layouts, paper spaces)
Ok thanks you !
Have a great day !
Have a great day !
Re: [SOLVED] dwg2pdf: export sheets (layouts, paper spaces)
Note for developers: If you want to export only Paper_Space or Model_Space use -block=".*Paper.*",".*Model.*"
