Outer contour generation seems impossible for this simple object (attached). Redrew it at least 10 times to make sure the lines all connect, turned around to see if it would work better, gave up after about an hour of trying. What is wrong here? Still incorrect connected lines?
Thanks for help,
Robert
[Solved] Contour generation fails
- test27.dwg
- (29.93 KiB) Downloaded 404 times
Linux Mint 20 , qcadcam-3.24.3.10-pro-linux-x86_64
Re: Contour generation fails
Nope - duplicates ...
You may doublecheck the big (R33) radii ...
Re: [Solved] Contour generation fails
Thanks...
Robert
Robert
