TreestumpExhaustpipe wrote: ↑Thu Jan 28, 2021 10:21 pm
Let me know how I can bulk erase. thanks at a different angle.
Great - looks like you are willing to try something new. I like it!
Ok, I stopped my time to finish that task. It takes me less than 5 minutes and I don't have to do this boring "Break out segments" over and over again ...
This is complex (at the first view!) so I will give you the procedure in small bites, ok?
We have to move/rotate the shape on the canvas. To get it later back in the right position we need 2 useful references to make it easy and bullet proof. I use circle in red on a layer called "Orig.Position". Lock that layer.
BTW: I use 3 Layer in total: Shape, Circuit-Type Hatching, Orig.Position.
- Husky-2021.01.28-06.png (58.12 KiB) Viewed 21166 times
Next step is to get the best benefits out of the "Box Joint from 2 Points". Best thing would be to align it horizontal with the longest line in our shape. For that we have to rotate the shape before we use the Box Joint tool. I used additional the "Alt" key to restrict the tool to 90 degree steps.
- Circuit-Type Hatching task stepbystep_1.gif (5.4 MiB) Viewed 21166 times
Just to be on the safe side I extended the Box joints on the left and right side ...
Ok, one done three to go ...
Tell me when you are at the same status and I'll give you the next step.
