Concrete Block Hatch For QCAD Pro
seasdes
Senior Member
Post by seasdes » Mon Mar 01, 2021 6:07 am
Here in Australia Concrete blocks are 390 mm long x 190 mm high. Mortar joints are 10 mm.
I need to place hatching that matches these exact dimensions.
I have never created a hatch pattern before.
Does anyone have a hatch pattern that matches these sizes or point me to a source or instructions how to create them.
seasdes
QCAD Pro V3.32.3
User since 2021
W11
Re: Concrete Block Hatch For QCAD Pro
Post by Husky » Mon Mar 01, 2021 7:05 am
Lucky you! I think a neighbor of you has a good solution for your problem :shock:
John Hyslop, a member of this forum, created a hatch pattern tool which can do exactly what you are looking for. The tool is called:
"Free Stand Alone Basic Hatch Pattern Tool" ...
... and can be downloadet from here:
viewtopic.php?f=30&t=6944&p=31023#p31023
It will help you without coding skills to design a hatch pattern like this one:
I used his tool already many times. :wink:
seasdes
Senior Member
Post by seasdes » Mon Mar 01, 2021 7:40 am
Thank you Husky and especially John.
What an excellent utility.
I suppose at 700 k John is a neighbour.
seasdes
QCAD Pro V3.32.3
User since 2021
W11
Post by John Hyslop » Fri Mar 05, 2021 11:39 pm
Thanks Husky :) much appreciated..
I hope you find this useful seasdes....
If you're interested in manually making your own patterns, I did a section in the forum
Hatch Patterns For Beginners
https://qcad.org/rsforum/viewtopic.php?f=47&t=6899
Hopefully soon there will be a tool inside Qcad written by CVH it's called Tile2Hatch I'm testing atm and it is excellent, it will take hatch patterns to another level..
All the best
