AutoCAD overkill command in QCAD?
Lucky I stumble upon this great AutoCAD alternative but one thing that keep me switching back to AutoCAD is the "overkill" command! For those unfamiliar, it is basically a way to clean up loose end from objects. We are talking about overlapping line, arc, circles, you name it. One button does it all.
From what I understand, QCAD have the Detect Duplicates (MD). Changing the tolerance would add more to you selections but it's limited and doesn't always detect. After that you need to join the lines with the polyline (og/oc) command. There is also the select filter. I have tried those in combination but it doesn't clean up properly.
I have the following files that I need to clean up. A rectangle with a bunch of small holes. If you examine one of the hole in AutoCAD with explode command, it will shows two half arc making that circle and some overlapping lines around on the rectangle.
How do I clean up the file to make sure there are no overlapping line at all with the least amount of step since there are many more files like this that would have more complicated shapes?
-Windows 10
-Version 3.25.2.0
-Windows 10
-Version 3.25.2.0
- petevick
Re: AutoCAD overkill command in QCAD?
did you forget to attach your files ??
Pete Vickerstaff
Sorry, here it is.
- Sample1.dxf
- (5.38 KiB) Downloaded 1044 times
I would not expect 'some overlapping lines' there and a QCAD explode returns 4 neat line segments.
When one uses the QCAD explode method on a Circle entity it will turn into a Polyline representing two semi-circles.
If one explodes those Polylines then they become two semi-circle Arc entities.
Nothing wrong with that.
I don't know how the circles got exploded.
Recently Andrew added an option in the QCAD settings to exclude the explosion of Circle entities.
Type 'TA' ... All 27 entities selected.
All 27 entities are accounted for. I don't find any overlapping entities.
The rectangle is a logical closed polyline with 4 vertices.
Sypher2012 wrote: ↑Wed Mar 03, 2021 2:27 pmIf you examine one of the hole in AutoCAD with explode command, it will shows two half arc making that circle.
Thanks CVH, I am using this file for a laser machine and if there are just 1 overlapping line or if it's broken down to two arc then the laser will follow that path. Meaning it will cut the first arc then the second arc to make the circle instead of one smooth clean motion.
One of the test I added in the line manually and forgot to do it in this sample. It doesn't seem to detect it unless I use the filter setting.
Can you upload your file for this one? It doesn't show in QCAD but what ever I do to this file to clean it up, AutoCAD overkill always find overlapping entities. It doesn't show in QCAD but AutoCAD finds them. Overkill combine combine those two arc in question.
What could be the benefits of a test file which is already clean ....Sypher2012 wrote: ↑Thu Mar 04, 2021 5:38 pmOne of the test I added in the line manually and forgot to do it in this sample. It doesn't seem to detect it unless I use the filter setting.
Anyway - assuming you are looking to clean up this sample file down to the polylines (9) I would just use the selection filter, search/select polylines, invert selection (TI), delete. No need to mess around with exploding, arcs etc.etc.
What you have suggested work. It look clean in QCAD but when I import the save file into AUTOCAD and run the overkill command. It shows 8 overlapping object(s) or segment(s) deleted. AutoCAD seems to automatically combine the arc cleanly and also can detect and remove the test line that I drew in QCAD.Husky wrote: ↑Thu Mar 04, 2021 11:32 pm
What could be the benefits of a test file which is already clean ....![]()
I am not knocking this program. I just want to understand a better/faster way of getting the job done in QCAD. I like how this program is mostly user driven.
We are standing in the dark ...
Following Husky guidelines you just deleted 16 Line segments and 2 Text entities.
Leaving only 9 Polylines.
With 9 Polylines + 1 mistery Line AutoCAD detects 8 overlapping object(s) or segment(s).
One would be that mistery Line you added + 7 others.
(9+1) minus 8 so 2 Entities remain ...
Or is it (9+1) minus (8+1) and only one entity remains?
It all makes no sense to me.
In your file 'Sample1.dxf' there are, 9 Polylines, 16 Line segments and 2 Text entities.
1 Polyline is a neat outer contour on layer 'CUT' with only 4 straight segments.
The other 8 Polylines on Layer '18' are circular shaped and probably were circles initially.
The 16 Line segments are by pair a cross in the 8 circle shaped Polylines, also on layer '18'.
2 Text on two different layers, 1 on 'SCRIBE' & 1 on 'TEXT'
One can't state that the 8 crosses and the 2 text overlap other entities.
Sure the 8 crosses are in the voids by the holes and the texts are on the plate.
In real live.
That is not what is meant by overlapping drawing entities.
What is the request here?
OverKill command : feature request by Andrew himself, early 2018.
https://www.ribbonsoft.com/bugtracker/i ... sk_id=1723
Although the summary is 'Detecting overlapping line / arc segments'
A method that surfaced many times when users fail to find such with QCAD method 'Detect Duplicates'.
The MD method is not intended for partially overlapping among other things.
BUT
None of the 27 entities in your file do overlap!
The 'one button does it all' won't fix what simply isn't there.
There only would be 16 semi-circle Arcs if you explode the 8 Polylines on Layer '18' yet again.
Why exploding them? I see no reason to do so.
Keep them as Polylines and laser cut them as 8 individual entities with a perfect and smooth round shape.
Let me add some questions:
- Why were those original Circle entities changed to circular Polylines in the first place?
- With what intention and with what application were those exploded knowing there is no easy way back?
- What was wrong with 8 Circle entities?
- What purpose have those 8 crosses while laser cutting?
- Why all the explode/investigate/overkill with AutoCAD?
I investigated the dxf sample file textual in detail: 988 text lines
>> There is nothing else as the known 27 entities in there.
Sounds like AutoCAD finds more than there actually is.
In Husky's words: What could be the benefits of a test file which is already clean ....
In other words: Send us your worst example file.
From my point of view there is nothing wrong with the one you posted:
The key questions here are:
A) How to revert back an explosion of Circle entities?
B)
For A) I could write a script based on:
https://qcad.org/rsforum/viewtopic.php? ... 592#p31590
Although, It served me more to exclude Circle entities from being exploded in the first place, even by accident.
For B) ? more complicated shapes ? We can only guess.
Try my sources instead. As engraver, I get horrible art designs.
I spent most of my time cleaning them up. There is no 'one click' solution for all.
For a sub 0.1mm engraving tip the paths have to be really smooth, I mean rather perfect.
On top, my CNC engraver won't stop/start at tangentially connected shapes.
Nor would it at nodes of circular Polylines.
Many start/stopping, but surely steep corners would kill my cutters.
A laser doesn't have that downside.
Looking forward for a really problematic example file.
BTW: I would really want to see those polylines with 1 full arc segment
In real live.
BUT
There are no Arc entities in your drawing!Sypher2012 wrote: ↑Thu Mar 04, 2021 5:38 pmMeaning it will cut the first arc then the second arc to make the circle instead of one smooth clean motion.
That is AutoCAD its problem.Sypher2012 wrote: ↑Thu Mar 04, 2021 5:38 pmAutoCAD overkill always find overlapping entities. It doesn't show in QCAD but AutoCAD finds them.
Please, attach such a file with 'the line' in it.Sypher2012 wrote: ↑Thu Mar 04, 2021 5:38 pmOne of the test I added in the line manually and forgot to do it in this sample.
That would be exactly your file because:
B)
Both have no easy answer.Sypher2012 wrote: ↑Wed Mar 03, 2021 2:27 pmHow do I clean up the file to make sure there are no overlapping line at all with the least amount of step since there are many more files like this that would have more complicated shapes?
Bitte:
Tick 'SELECT ALL', copy and save it as a *.js file (eg. CircPoly2Circ.js)
Run it in QCAD on a selection with Menu Misc .. Development .. Run Script (XC).
// Full circular Polylines with 2 Arc segments to Circles script by CVH
var doc = getDocument();
var di = getDocumentInterface();
var polysCollected = [];
// Retrieve the selection:
var ids = doc.querySelectedEntities();
// Terminate without selection:
if (ids.length === 0) {
EAction.handleUserWarning("Nothing Selected! Script terminated.");
return;
// Filter full circular Polylines with 2 Arc segments from selection:
for (var i=0; i<ids.length; i++) { //Cycle selected entities
// Get entity from the document:
var entity = doc.queryEntity(ids[i]);
// Collect when exist and is full circular shape:
if (!isNull(entity)){
if (isClosedPolylineEntity(entity)) {
if (entity.countVertices() === 2) {
if (RMath.fuzzyCompare(entity.getBulgeAt(0), 1.0) && RMath.fuzzyCompare(entity.getBulgeAt(1), 1.0)){
polysCollected.push(ids[i]);
} // Loop selected entities
// Terminate without full circular Polylines in selection:
if (polysCollected.length === 0) {
EAction.handleUserWarning("No full circular Polylines selected! Script terminated.");
return;
// Setup an operation:
var operation = new RModifyObjectsOperation();
operation.setText("Full circular Polylines to Circles");
// Process collected Polylines:
for (var i=0; i<polysCollected.length; i++) { //Cycle collected Polylines
// Get full circular Polylines from the document:
var fullPoly = doc.queryEntity(polysCollected[i]);
var centerRv = RVector.getAverage(fullPoly.getStartPoint(), fullPoly.getVertexAt(1));
var radius = fullPoly.getStartPoint().getDistanceTo2D(fullPoly.getVertexAt(1)) / 2;
// Create a new Circle entity:
var newCircle = new RCircleEntity(
doc,
new RCircleData(
centerRv,
radius
// Add the new Circle to the operation:
operation.addObject(newCircle, false, true); // NOTuseCurrentAttributes, DOforceNew
// Mark the full circular Polyline to delete:
operation.deleteObject(fullPoly);
} // Loop collected Polylines
// Apply all modifications:
di.applyOperation(operation);
// Finished:
var msg = "Created " + polysCollected.length + " Circle entity/ies."
EAction.handleUserInfo(msg);
EAction.handleUserMessage("Script ended.");
return;
Great detective work there CVH, you're not wrong on many count. It might be AutoCAD itself that is the problem because I have a certain workflow that I do and when I tried to do the same in QCAD, it is where I got a different results. I've attached a cleaned out file from AutoCAD perspective on what it say a problem free file should be. Your script actually does a better job and in this case for me and shows a file that AutoCAD have ZERO problem with..
There is something that I must be doing wrong on the detect duplicate command and the detect zerolength command. I place 2 of the following object as a simple test but it failed to detect both. See attachment file Sample1 Fail.dxf
1. I drew a square matching all four corners and sitting exactly on top so pretty much a duplicate
2. I drew a broken line segment from one corner to the other end, still overlapping
- Sample1 fail.dxf
- (101.06 KiB) Downloaded 984 times
- Sample1 cleaned.dxf
- (101.29 KiB) Downloaded 949 times
Hi again,
Now I see circles. Did you used the script?
Sample1 cleaned.dxf is clean as a whistle.
8 circles and 4 lines.
In QCAD simply type 'TA' and look at what the 'Selection' returns in the Property Editor.
Although I would prefer the outer contour as a Polyline.
One single neat closed chain of line segments.
Sample1 fail.dxf
TA >> 14 Entities and I only see 9 or 12 depending the contour is 1 or 4.
MD, 0.001 Distance & Angle Tolerance, ignore direction, ignore layer
Any QCAD tool with settings shows these on the Options Toolbar.
That finds 1 duplicate line at the bottom.
Close the tool.
Alt+Select the lower horizontal
>> Poly 4400 + Line 1100 + Line 1100
The last two are exact duplicates, one of the two is found by MD
Alt+Select the higher horizontal
MD doesn't consider this as duplicates
Alt+Select left or right vertical
MD doesn't consider both Lines as duplicates
Like I mentioned, QCAD MD will not find partial overlapping, among others.
Here the Overkill would come into play.
A Line entity 1100 long matches one segment of the Polyline.
Now what you don't want to do is TA, OC, to create 2 Polylines that would match.
Two reasons:
- The contour becomes a Poly with 10 vertices, all Lines merge with the Polyline.
- Even disregarding not exploding circles (Application Preferences), they become polylines with 2 semi-circles Arcs.
Thanks for letting me discover the second.
An other thing to worry about in the future.
I will request to exclude Circles from OC.
Sample1 fail.dxf
Close the tool.
Two reasons:
Hi Sypher2012
1st Great work CVH very handy script and downloaded
Just a tip if I may add my 2 cents worth.
I have been creating patterns for laser cutters for 20 odd years and also missed the
Overkill command when moving across to Qcad.
Until one day I tried something ..
After running MD & MZ try "Solid Hatch" this will pick up overlapping entities,broken
profiles and small gaps , it displays the positions in red in the command line where the problem is,
what I do is draw a circle at those co-ordinates then fix the problem up, I sometimes
have to do this multiple times to catch all the errors.. It's worked for me, just thought
I'd pass on..
Most of the time it comes from a pattern supplied to me to fill a sheet up for a screen
and the pattern has errors and sometimes I myself might miss something or have a line
not trimmed correctly..
PS Try this out with the attached file and you'll see what I mean
It shows where all the faults are and you can fix up one by one
I'd pass on..
- test.dxf
- (196.66 KiB) Downloaded 1025 times
Thank you both CVH and John for your suggestions.
John: I think that is a very creative way on finding open area in a drawing! I never thought about doing like that but will have to try to add that in to my QCAD workflow now.
CVH: I have uploaded a sample2 file that is more complicated than the first one.
Another way of thinking of the "overkill" command is a tool that would flatten or condense current selections. Something that would stripe it down to it's bare minimum without changing what it would look like in the final render. Not sure if there is a QCAD equivalent.
- Sample2.dxf
- (145.06 KiB) Downloaded 1060 times
Hi Sypher2012
I know the method I mentioned isn't anyway as good as the overkill command but I'm pretty sure someone might be able to create a tool for this eventually but just wanted to share another way of checking files for laser cutting hatching will also find overlapping entities
There is a command Flatten though.. It's here
Misc>Modify>Flatten Drawing to 2D.
Basically sets all Z entities to 0..
Hope this helps
Hope this helps
