UPDATED 3.04: Import and draw entities from a CSV file
Post by CVH » Thu Feb 18, 2021 3:45 pm
Based on the same basic principle as these:
https://www.qcad.org/rsforum/viewtopic.php?t=7497
viewtopic.php?t=7544
And posted especially for Kramerica:
viewtopic.php?f=32&t=8116
Installation:
Close QCAD
Create a new folder ...QCAD\scripts\Misc\Examples\IOExamples\DrawFromCSV (Mandatory)
The script file is called ...QCAD\scripts\Misc\Examples\IOExamples\DrawFromCSV\DrawFromCSV.js (Mandatory)
Simply copy the files and the icon over to the DrawFromCSV folder.
Start QCAD
There should be a newly added menu item under Misc .. Script Examples .. Import/Export
It should have an icon.
The command is 'drawcsv' but I can't come up with a good and available shortcut.
There are two test files included:
- One for the 'real' CSV style with comma and dot.
- One for the CSV style with semicolon and comma.
- Semicolon and dot is also accepted.
- The script looks up your local QCAD list separator setting. (mine is the EU style)
- What to include in a CSV is also listed in the test files.
Scripts are textual files, a lot of readable info is in the script itself.
Any comment or request welcome.
Only don't ask me for money or world peace. :wink:
The script may be completed and updated in due time.
This one is hustled together with copy/paste.
Kind regards,
*** EDIT ***
This was the Beta version and was downloaded 46 times before the 3.01 update.
Another 108 times before the 3.04 update.
Please see lower for the latest release (v3.04).
*** EDIT ***
DrawFromCSV.zip
(22.43 KiB) Downloaded 1367 times
Update: Import and draw entities from a CSV file
Post by CVH » Wed Apr 07, 2021 4:54 am
Major update 3.01:
Result from DrawCSV_test.csv (or EU)
Supports:
- Different CSV styles
- Layer handling, layer attributes
- Entity general attributes
- Entity custom properties
- Custom origin (logical UCS), last relative position (conform QCAD).
- Absolute, relative & relative/polar notation.
Draws:
- Point, Line, Vector, Ray, XLine
- Arc, Arc3P, Circle, Circle+P, Circle3P
- Triangle, Square, Rectangle, Quad, Polygon
- Polyline, FitSpline, ControlSpline
- Text
Extra:
- LineTo, VectorTo, ArcTo+A, ArcTo+R (Starting from the last position)
- Solids: 3 & 4 point solids
- Select all / Zoom to all
Included are documentation, test and example files.
CSV files include comments.
Andrew is provided in a copy that might be included under Misc .. Import/Export in future releases of QCAD.
Any comment or request is welcome.
Kind regards,
*** EDIT ***
This version was downloaded 135 times before the update.
*** EDIT ***
DrawFromCSV_v3.01.zip
Complete zip package
(624.38 KiB) Downloaded 1160 times
DrawCSV_doc.pdf
Method documentation
(83.33 KiB) Downloaded 1295 times
Immediate installation:
Close QCAD
Simply copy the files, icons and subfolders over to the DrawFromCSV folder.
Start QCAD
Re: Import and draw entities from a CSV file
Post by andrew » Wed Apr 07, 2021 10:29 am
Thanks for your contribution!
I've added this to https://github.com/qcad/qcad/tree/maste ... rawFromCSV
Kramerica
Re: UPDATED: Import and draw entities from a CSV file
Post by Kramerica » Mon Apr 19, 2021 6:47 pm
Looking forward to this update!
Post by CVH » Thu May 06, 2021 5:02 pm
All,
Downloaded QCAD version 3.26.2.0 just now and installed it.
I can confirm that DrawFromCSV is included in the standard installation. :P
Thanks, Andrew. :wink:
Kind regards,
Post by CVH » Sat Nov 20, 2021 9:26 am
Hi all.
Some minor changes:
- Bug fix: Last validated reference may serve as relative position before something valid was cast.
- Bug fix: Undefined layer hierarchy separator for CE users. Reverted to ' ... ' aka three dots in such a case.
- Added some more obvious input validations.
- Temporarily turns off warnings and info messages by dialogs.
There we might expect a large amount of dialogs to be confirmed with flaws in the CSV file.
User settings are restored afterwards.
- Removed exclamation marks from warning messages. (Sorry Andrew :oops:)
- Reviewed all messaging.
- Added an experimental method for rounding polylines at corners what requires QCAD Professional.
Of benefit for laser and plasma cutters were hard corners may scorch the workpiece by the discontinued motion.
Uses the standard QCAD Pro resource but avoiding arc segments, self-intersections and too large radii.
Only applicable on polylines methods that cast polyline with line segments, intended for small roundings.
Please find the updated (new) files below.
DrawFromCSV.js
DrawFromCSV Addon script version 3.04
(103.47 KiB) Downloaded 925 times
DrawCSV_doc3.pdf
Methods specification revision 3
(95.96 KiB) Downloaded 1045 times
DrawCSV_Rounding_test.csv
Experimental rounding test CSV file
(2.31 KiB) Downloaded 959 times
