Dashed line - Width
dublinline
Dashed line - Width
Post by dublinline » Mon Jul 19, 2021 11:40 pm
I wonder how I can change the width of a dashed polyline.
My dashed polylines only shows dashed when the value for Global Width is set at 0.
As soon as I try to make it thicker (eg set the value at 5), the line shows continuous but not dashed.
Any help would be much appreciated.
Working on Windows 10 Home,
QCAD version 3.26.4.0
Re: Dashed line - Width
Post by andrew » Mon Jul 19, 2021 11:48 pm
Linetype patterns can only be used for standard line weights (property "Lineweight"), not custom polyline segment widths (properties "Global Width", "Start Width" and "End Width").
dublinline
Post by dublinline » Tue Jul 20, 2021 12:15 am
Hi Andrew,
thanks for your fast reply.
The widest 'Lineweight' I could see was 2.11mm, would there be a way to increase this value, say to 5 mm please?
Many thanks,
Post by CVH » Tue Jul 20, 2021 3:41 am
The available 'Lineweights' are rather standard among CAD applications.
Please explain why you need a thicker patterned weight.
dublinline
Post by dublinline » Tue Jul 20, 2021 10:22 pm
I wish to show a dashed line more prominent,
the 2.11 mm line would not stand out sufficiently.
Many thanks for any other suggestions.
Post by Husky » Tue Jul 20, 2021 10:43 pm
What represent that line? Do you have an example drawing / screenshot which shows what you are trying to accomplish?
