dashed linetype (circles ve lines) SOLVED
bambuko
Post by bambuko » Wed Sep 01, 2021 10:18 am
I am using dashed line, Dashed (.5x) to be precise, scaled at 0.1 to draw some lines and circles.
Lines display OK, but circles appear solid and not dashed :?
I am confused...
help, please
QCad Pro
Linux MX-23.5_KDE_x64 Libretto
Re: dashed linetype (circles ve lines)
Post by andrew » Wed Sep 01, 2021 10:23 am
Please always attach your file so we can help efficiently, thanks.
bambuko
Post by bambuko » Thu Sep 02, 2021 9:29 pm
Sorry, didn't think it was worth attaching a file with a single circle in it :lol:
I am travelling at the moment without access to Qcad, so will not be able to do it until I am back, but I will asap.
QCad Pro
Post by Husky » Thu Sep 02, 2021 10:38 pm
Going to hijack this topic for a moment ... :shock:
I am confused...
Yep, that annoys me for some time too ...
All entities are on the same layer, Dashed .5, 0.35, no scale, Screen-Based Line-types mode "ON", unfortunately (confusingly!) correct rendering fails for arcs and circles.
dashed.dxf
(102.77 KiB) Downloaded 835 times
... back to bambuko! :lol:
Post by CVH » Fri Sep 03, 2021 7:12 am
Same here: :wink:
A: Not using Screen Based the Linetype Scale has to be adequate in relation with the drawing size.
B: Solved for splines entities a while ago.
C: The dashes reappear at a certain deeper zoom state.
D: For some entities dashes may reappear with a higher minimum rendering angle step value.
(App.Prefs. Appearance; Default is 0.2).
bambuko
Post by bambuko » Fri Sep 03, 2021 8:17 am
Thank you guys,
glad I am not alone :wink:
I have tried different linetype scales to no avail,
I have tried zooming in - made no difference
The only thing I haven't tried is to plot it to see whether it is just display that is wonky
will try rendering angle step when I get back home, but....
as far as I am concerned it is a bug :mrgreen:
QCad Pro
Post by CVH » Fri Sep 03, 2021 8:46 am
With Husky's file. ScreenBased.
At this zoom state the larger circle looks dashed.
The polyline arc right-low not yet.
There the dashes will reappear when zooming in to about 2x2 units.
For the 1/4 arc in the middle of the drawing dashes will reappear somewhat in between those zoom states.
So it seems radius related ... :?
Post by andrew » Fri Sep 03, 2021 9:48 am
bambuko
Post by bambuko » Fri Sep 03, 2021 6:54 pm
Thank you!
I guess this is another one that should appear at next release?
QCad Pro
bambuko
Re: dashed linetype (circles ve lines) SOLVED
Post by bambuko » Sun Sep 19, 2021 10:02 am
Solved with latest (3.26.4.7) - thank you.
QCad Pro
