Duplicate Layout Block
dmitpon
Post by dmitpon » Wed Jan 12, 2022 5:54 am
I have written a script to duplicate a layout block. But it uses the proprietary LayoutDialog class. Is it allowed to publish it on the forum or is it a violation of the license? The source code of the LayoutDialog class is not used in the script, only the method is overridden.
var dlg = new LayoutDialog(doc, undefined, false);
    // override method LayoutDialog.show()
    dlg.show = function (layoutName) {
        this.dialog = WidgetFactory.createDialog(LayoutDialog.includeBasePath, "LayoutDialog.ui", EAction.getMainWindow());
        return layout;
Re: Duplicate Layout Block
Post by andrew » Wed Jan 12, 2022 9:42 am
Yes, that's fine. Be sure to exclude your script from the QCAD Community Edition in your init:
MyAction.init = function() {
    if (!hasPlugin("PROTOOLS")) {
        return;
ryancousins
Post by ryancousins » Thu Jan 13, 2022 4:08 pm
dmitpon,
Thank you for doing this! I'm looking forward to trying the script out as I often need to duplicate layout blocks.
dmitpon
Post by dmitpon » Sat Jan 15, 2022 4:58 am
ONLY FOR PRO VERSION!
DuplicateLayoutBlock.zip
(3.97 KiB) Downloaded 1722 times
To duplicate the layout block, right-click on the desired layout block and select Duplicate Layout Block from the context menu
dmitpon
Post by dmitpon » Sat Jan 15, 2022 5:16 am
Post by CVH » Sat Jan 15, 2022 7:25 am
Thank you for your contribution. :P
There the script is that basic ...
... I now start to wonder why this wasn't implemented by Duplicate Block (BY) in the first place.
Post by Husky » Sun Jan 16, 2022 1:16 am
Looks good so far. Thank you!
Question: I noticed that the entities in a copied layout block use the same Draw Order numbers like the source. Does that doesn't causes any trouble?
Post by CVH » Sun Jan 16, 2022 5:18 am
Duplicate drawing orders are never an issue.
CVH wrote:
Thu Jan 13, 2022 4:59 am
e.g. Open a file, select 10 entities, MB, all 10 have order -1, save & close, re-open ...
The new drawing order of those 10 is 0-9 and correlates with their handles, the rest is shifted.
Also try:
DP or copy/paste, the draw order of the duplicate is the same as the original.
That is, until you re-open the file.
The handle is not, that is unique.
Post by CVH » Sun Jan 16, 2022 8:40 am
dmitpon,
Entities drawn in a layout block (e.g. Viewports) that are on locked layers are not copied.
This may be intentional or not.
One can set AllowAll() for an ROperation:
https://qcad.org/doc/qcad/3.0/developer ... 52dc203696
But I don't see how that would work using CreateBlock.createBlock(...) :?
The workaround would be:
- 'As is' add layer state (YM) for safekeeping
- Unlock all layers (YN)
- Duplicate Layout (22)
- Activate the original layer state back
dmitpon
Post by dmitpon » Sun Jan 16, 2022 9:46 am
Hello CVH,
Duplicate Block (BY) also does not copy entities on locked layers. Prints a warning message on the Command Line:
Transaction failed. Please check for block recursions and locked or invisible layers or blocks.
IMHO, this is normal behavior
Post by CVH » Sun Jan 16, 2022 10:00 am
I was aware of that, it uses the same resources.
Wouldn't it be nice that a copy of a block is simply a copy without the hustle with the layer states?
dmitpon
Post by dmitpon » Sun Jan 16, 2022 12:13 pm
I can't answer this question. For a year of work of the QCAD (more than 50 real projects), I have never experienced such a problem. Maybe I have a different workflow.
Post by CVH » Sun Jan 16, 2022 12:31 pm
Maybe you don't need to or use locked layers at all. :wink:
I many cases I can't work without.
