Andrew,
Looking into conversion factors for U.S. survey Feet/Inch/Yard/Mile I stumbled on:
RS.Astro = 149 600 000 000m (+14ppm)
Since sept. 2012 that is defined as exactly 149 597 870 700 meter
Internationally represented as 'au'.
RS.Lightyear = 9 460 731 798 000 000m (+0.14ppm)
Since 1984 defined as exactly 9 460 730 472 580 800 meter
RS.Parsec = 30 857 000 000 000 000m (+7ppm)
Since 2015 defined to the nearest meter as 30 856 775 814 913 673 meter
What I don't seem to pinpoint is what other CAD systems use for these conversion factors ...
Or what the dxf standard is ... And if that is updated ...
ezdxf uses the exact factor for 1au but not for Lightyear and Parsec.
Further:
In RUnit.cpp there is a trace of a unit called 'Plu' = 0.025mm what is about one 'Mil'.
Also, if I am not mistaken then isMetric() would return true for RS.Microinch.
Units conversion factors
Jump to
- General
- ↳ Announcements
- ↳ Chat
- ↳ Site Feedback
- ↳ Pre-sales Questions
- ↳ Introduce Yourself
- QCAD Professional Version
- ↳ QCAD 'How Do I' Questions
- ↳ QCAD Suggestions and Feedback
- ↳ QCAD Voting Corner
- ↳ QCAD Troubleshooting and Problems
- ↳ QCAD Installation and Upgrades
- ↳ QCAD Programming, Script Programming and Contributing
- ↳ QCAD 'Script Add-On & Plug-in challenge' - Work in Progress
- ↳ Finished 'Ready to go' Scripts/Plug-in's
- ↳ QCAD Tips and Tutorials
- ↳ QCAD/CAM
- ↳ What do you use QCAD/CAM for?
- QCAD Community Edition
- ↳ QCAD Community Edition
- International Forums
- ↳ Français
- ↳ QCAD Professional
- ↳ QCAD/CAM
- ↳ QCAD Community Edition (Version 3)
- ↳ Deutsch
- ↳ QCAD/CAM
- ↳ Italiano
- ↳ QCAD/CAM
- ↳ Español
- ↳ QCAD/CAM
- ↳ Português
- ↳ QCAD/CAM
- ↳ Nederlands
- ↳ QCAD/CAM
- QCAD Book
- ↳ QCAD - An Introduction to Computer-Aided Design
- ↳ QCAD - Una Introducción al Diseño Asistido por Ordenador
- ↳ QCAD - Eine Einführung in computerunterstütztes Zeichnen (CAD)
- QCAD Part Libraries
- ↳ General
- ↳ Creating DXF/DWG items
- ↳ Creating SVG items
- ↳ Meta Data
- dxflib
- ↳ dxflib Suggestions and Feedback
- ↳ dxflib 'How Do I' Questions
- ↳ dxflib Troubleshooting and Problems
