Hi.
Version: 3.29.6.0 (3.29.6), Windows 10 Pro.
I again have problems opening a QCAD DXF file with solidworks. Quite a few years ago, I had the same problem with the free version and Linux.
DXF opens OK in several online viewers.
Any suggestions ?
Thx
Solidworks doesn't like QCad's DXF
- Registered Member
Re: Solidworks doesn't like QCad's DXF
did you save the dxf in Qcad in a file format like R27 which is compatible with your SW software?
