Printouts are blank
bozzle
Printouts are blank
Post by bozzle » Sat Mar 22, 2014 3:12 pm
I have just started to use qcad community but when I try to print I only get blank pages. PDf's are also blank, despite being OK in preview and getting "export complete" message in command toolbar I have adjusted paper and drawing units to match and can see page outline. Operating on XP Do I need the pro version?
Any ideas would be much appreciated.
[Edit by Mod, topic moved to Community Edition forum]
Papy Octet
Re: Printouts are blank
Post by Papy Octet » Sat Mar 22, 2014 3:37 pm
Are you shure you are not drawing in with color ?
Debian 9 - Qcad-Prof 3.6
bozzle
Post by bozzle » Sat Mar 22, 2014 4:57 pm
I have used colours on drawing and in drawing preferences the printing is set to colour so I assume it should be visible
Post by Clive » Sat Mar 22, 2014 5:13 pm
Hi bozzle
Welcome to the forum
bozzle wrote: Do I need the pro version?]
No, not for printing.
From your explanation it seems you are doing things correctly, however if you cannot resolve this problem are you able to set up a simple example drawing and post it here on the forum, so we can test it out?
bozzle
Post by bozzle » Sat Mar 22, 2014 5:31 pm
Clive,
I can copy with printscreen but cannot paste to this reply
Post by Clive » Sat Mar 22, 2014 5:45 pm
You can reply and attach a dxf using the 'Upload attachment' option under the message box.
Upload Attachment.png (12.79 KiB) Viewed 8402 times
Post by Clive » Sat Mar 22, 2014 5:47 pm
bozzle wrote:Clive,
Or unless this file is private of course, that's why I suggested to draw up a quick example file and attach it so that we can try to reproduce the issue and resolve it.
[Edit: Just had another thought about this problem, check your line weights are not 0.00]
bozzle
Post by bozzle » Sat Mar 22, 2014 7:07 pm
Clive,
Line weight is 0.35mm File attached
test1.dxf
(17.35 KiB) Downloaded 246 times
bozzle
Post by bozzle » Sat Mar 22, 2014 8:01 pm
Do not understand what happened as file no longer exists on my pc. Please find another one
When I boot up I only get to 97% then get a message "report translation error" which may have followed me cancelling purchase options. Should I reinstall?
test2.dxf
(19.5 KiB) Downloaded 255 times
Post by Clive » Sat Mar 22, 2014 8:17 pm
Test2 opens fine for me and exports to pdf without problems.
'Booting up to 97%' , please explain - is this with test1, test2 or something else.
Post by Husky » Sat Mar 22, 2014 9:04 pm
Hi bozzle,
your Drawing Unit and your Paper Unit is right now adjusted for Meters ... what means your Paper size is 210x297 Meters. Maybe a little bit to big for your Printer :wink:
Please change the settings to mm. You can do that for the current drawing below:
Edit / Drawing Preferences / General / Drawing Units
Or if you like to have this settings for all new drawing:
Edit / Application Preferences / Defaults for new drawings / Drawing Unit
Hope this will fix the print problem. If not .... :wink:
bozzle
Post by bozzle » Sun Mar 23, 2014 12:39 am
Guys,
Having adjusted paper size the print function operates as expected. Many thanks for your help
Post by Clive » Sun Mar 23, 2014 10:24 am
Hey bozzle, glad you got this sorted out, enjoy QCAD :wink:
Ahh shoot, I missed the obvious with this one :roll: thanks.
