Free Hatch Patterns
Re: Free Hatch Patterns
Post by John Hyslop » Mon Nov 15, 2021 8:47 am
Hi All
Designs by Husky
CEMETERYS - Metric and Imperial.zip
(2.35 KiB) Downloaded 1540 times
Post by John Hyslop » Mon Nov 15, 2021 9:04 am
Me Again :D
Design by Husky
GRASS-01 - Metric and Imperial.zip
(1.2 KiB) Downloaded 1565 times
Post by John Hyslop » Mon Nov 15, 2021 9:27 am
Hi
Design by Husky
HILLS - Metric and Imperial.zip
(2.13 KiB) Downloaded 1505 times
Post by John Hyslop » Mon Nov 15, 2021 9:41 am
Design by Husky
CLEARED_LAND - Metric and Imperial.zip
(1.96 KiB) Downloaded 1512 times
Post by John Hyslop » Mon Nov 15, 2021 10:02 am
:) ...I'll do more later...
Design by Husky
OCEAN - Metric and Imperial.zip
(2.18 KiB) Downloaded 1511 times
Post by John Hyslop » Tue Nov 16, 2021 3:28 am
Good Afternoon :)
Design by Husky
MOUNTAINS - Metric and Imperial.zip
(1.39 KiB) Downloaded 1416 times
Post by John Hyslop » Tue Nov 16, 2021 3:30 am
Hi All
Designs by Husky
CROPS - Metric and Imperial.zip
(2.99 KiB) Downloaded 1415 times
Post by John Hyslop » Sun Nov 28, 2021 9:51 am
Hi All
I was playing around with my "Basic Hatch Pattern Tool" & remembered you could do a Basket Weave Pattern
It's a common Brick Paving Pattern, All you need to do is set the Width & Height the same in my program and
tick the "Double Weave" box that's it :)
It can be downloaded at https://www.qcad.org/rsforum/viewtopic. ... =15#p33566
Pattern Created is a 12x6 Brick :)
BASKET WEAVE.png (9.39 KiB) Viewed 43541 times
Post by John Hyslop » Fri Dec 17, 2021 4:16 am
Hi All
Wishing everybody best wishes for the festive season...
I thought I'd sneak in one more pattern before the end of the year..
An addition to my lattice patterns :D
LATTICE-12 - Metric and Imperial.zip
(1.44 KiB) Downloaded 1431 times
Post by John Hyslop » Sat Jan 15, 2022 11:23 am
Hi All
I had a panel that required a honeycomb grille pattern, so I thought it would be easier to create a pattern
explode it and trim off the excess, it worked a treat so I'm sharing it with you all... Top panel in the picture is the
job I did today in Qcad.. :D
HONEYCOMB - Metric and Imperial.zip
(2.16 KiB) Downloaded 1357 times
Post by John Hyslop » Thu Jan 27, 2022 9:44 am
Hi All
The above pattern can now be created any size and with any gap you like... or no gap :)
My Basic Hatch Pattern Tool now includes an editable honeycomb pattern it can be downloaded here:-
https://www.qcad.org/rsforum/viewtopic. ... 4&start=15
BHT-V3.1.0 - Honeycomb.jpg (62.08 KiB) Viewed 42384 times
Post by John Hyslop » Mon Feb 28, 2022 2:53 am
Hi All
I've made 2 new patterns below.. Please note some of my patterns can be used for decorative panels
eg Corten "rusty looking metal" screens etc...simply scale pattern explode and trim to suit.. enjoy.. :D
LATTICE-13 - Metric and Imperial.zip
(1.35 KiB) Downloaded 1423 times
3-ARROWS - Metric and Imperial.zip
(1.87 KiB) Downloaded 1168 times
Post by John Hyslop » Tue Mar 01, 2022 5:10 am
Another Arrow Pattern :lol:
2-ARROWS - Metric and Imperial.zip
(1.84 KiB) Downloaded 1409 times
Post by John Hyslop » Mon Mar 14, 2022 4:04 am
Hi All
1st a big thank you to Husky for this suggestion and also help on info supplied in PDF included in zip file.. :)
ROOF-SHINGLES - Metric and Imperial.zip
(231.35 KiB) Downloaded 1224 times
Fixed Typo in PDF file "Downloaded 4 times"
PS These of coarse are only some samples of scaling , you can scale any size you like :)
Post by John Hyslop » Sun Mar 20, 2022 3:25 am
Hi All
Another Pattern Taking Scaling into Consideration...
I left a small gap between the rows so the pattern can easily be aligned with the cavity without showing the next row..
Consider Using LineType "Batting" , Never Knew This Existed. :oops: .. I'll Leave This One Here Anyway :D
INSULATION-01 - Metric and Imperial.zip
(112.03 KiB) Downloaded 1678 times
Insulation-01 - Metric Example.png (30.58 KiB) Viewed 41061 times
Insulation-01 - Imperial Example.png (34.7 KiB) Viewed 41061 times
