Drawing Header
Locked
venkatkoka
Drawing Header
Post by venkatkoka » Wed Jan 13, 2010 10:20 am
How to create a standard sheet (e.g, A4 or A3) with a standard table which has data such as Material, Customer, Change Management Data and so on (as on a Standard Engineering Drawing Sheet)?
Parts of the information in this table should be changed for every new drawing.
Thanks in advance,
V
J-J
Moderator
Post by J-J » Wed Jan 13, 2010 7:36 pm
Hello
Have a look in the Library directory under templates, you can start from what's there and modify to suit your needs.
good luck,
JJ
venkatkoka
Post by venkatkoka » Thu Jan 14, 2010 7:50 am
Thank you very much J-J for the reply...
I found a file in "misc" directory of Library Browser which is "A3" of size. Can we also get an "A4" sheet?
Once again thank you very much!
Venkat
J-J
Moderator
Post by J-J » Thu Jan 14, 2010 11:16 am
Have you found the sub-directory "templates\fr". There should be an "A4 NF" in it. If not I can email the A4 to you.
JJ
venkatkoka
Post by venkatkoka » Thu Jan 14, 2010 12:40 pm
Hi There,
I did not find any sub-directories in the templates. It would be great if you could e-mail me...
Thanks alot,
Venkat
J-J
Moderator
templates
Post by J-J » Fri Jan 15, 2010 9:52 am
Did you receive my personal message asking for your email?
I think I found the templates on another site, I'll be happy to forward them to you.
JJ
Locked
