QCAD-Converting dxf file to work with Vinyl Cutter Plotters
Locked
jocpo
Post by jocpo » Sat Feb 06, 2010 5:44 pm
I use QCAD to create clocks dial templates for my son. I want to buy a vinyl cutter plotter to plot and make the templates/stencils. A tech person from a local firm was unable to use the dxf file or the various exported files. He suggested using Corel Draw or Illustrator to create the dials. I like QCAD and prefer to use it to create the work.
I saw on the RibbonSoft site a "vec2web download that converts files. I downloaded it but don't understand how to apply it to QCAD. Also I'm not sure this will solve my problem.
I run on QCAD on Macs-OS X Tiger and OS X Leopard.
Is there some easy and inexpensive solution to get the QCAD drawings to work with a vinyl cutter? I'm not a computer wizard but want to help my son out and do the dials and cutting.
Post by andrew » Mon Feb 08, 2010 12:15 pm
What file format did the person from the local shop want or prefer?
Post by andrew » Mon Feb 08, 2010 4:40 pm
I don't know what I need. I'm looking at a Graphtech vinyl cutter. When I met with the Graphtech sales person he tried to open all of the files that I brought. I even opened one of the jpeg files in Photoshop (exported from QCAD) and saved it as an EPS file. He was unable to open it with the cutter.
I'm at a loss as to what to do next.
I really like QCAD. It's simple and fast. I really don't want to create my dials with any other graphics program, but maybeI need to consider it.
I'll try to research this matter further and see if I can resolve it.
A bitmap saved as EPS does not contain any lines and arcs anymore (just pixels), so that's no good.
If the vinyl cutter accepts EPS files, you can create a PDF file with QCAD and convert that to EPS or create a PS file with a PS printer driver and convert that to EPS. EPS, PS and PDF are all closely related.
jocpo
Post by jocpo » Mon Feb 08, 2010 5:28 pm
I'll try some the file conversion methods you discussed.
Thanks for your prompt rely regarding this matter. When I resolve it, I'll share the solution with the forum.
Locked
