Running 3.32.5.0 (3.32.5) on W11
Have been happily drawing yesterday, but as from the first use today I cannot draw any sort of line in the drwaing I started yesterday (see attached).
What am I missing?
Thanks for your help!
Arjan
Can't draw a line from Qcad in default state ?!
Buntehuhn
- fuselage_forum20251228.dxf
- (5.11 MiB) Downloaded 17 times
Re: Can't draw a line from Qcad in default state ?!
On opening layer 'lasersnijdbaar' is the current active layer.
This attribute is stored in the DXF.
Most drawing tools draw on the current active layer.
Layer 'lasersnijdbaar' is set invisible and frozen and that means that you can not draw on it.
You should have noticed a red warning message in the Command Line history in the nature of:
'Transaction failed. Please check for block recursions and locked or invisible layers or blocks.'
Buntehuhn
