Qcad Crashes When Selecting Symbols Folder in Library Browser
RMK-Designs
Post by RMK-Designs » Fri Jan 16, 2026 3:19 pm
I am working on a home addition drawing and went to look at what symbols are in the library browser in the symbols folder but when clicked on it the program crashes. I tried this several times with the same results. I tested the other folders in the browser which work as they should and I can insert items from these folders. Does this folder conatain and any items? Thanks for your help
Qcad 3.32.5.0
Windows 11 Pro
Re: Qcad Crashes When Selecting Symbols Folder in Library Browser
Post by CVH » Fri Jan 16, 2026 3:51 pm
Looks like a similar report as on the German forum:
Absturz nach abruf des Bibliothekbrowsers
It seems it is related to SVG library items.
Post by andrew » Fri Jan 16, 2026 3:52 pm
Thank you for your report. Bug report at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2702
