CAM Expert 2.0.4.9 Demo FREEZE on run
If you are having problems with CAM Expert, post here. Please report bugs here.
Roger
Postby Roger » Tue Apr 27, 2010 12:57 pm
I've downloaded CAM Expert 2.0.4.9 Demo Windows Installer from QCAD.org website.
I've installed it and when I RUN CAM Expert Demo (the last question of installer), the startup frame with RibbonSoft logo and "Loading.." text is running between 50% and 99% of CPU and never enters to program UI. the only thing I can do is Ctrl+Shit+Esc and finish process.
I'm running Windows XP with SP2.
Any solution? Thank you.
Postby andrew » Wed Apr 28, 2010 8:02 am
Unfortunately, if the CAM Expert demo doesn't work on your particular Windows installation, neither will the full version.
Roger
Postby Roger » Wed Apr 28, 2010 8:13 am
So what Windows XP is told to run with "Windows Version" CAM Expert? Maybe XP without SP?
I'm going to try Ubuntu 9.10 with libstdc++.so.5 version
Thank you.
Return to “CAM Expert Troubleshooting and Problems”
Users browsing this forum: No registered users and 0 guests
