convert dxf which contains picture
If you are having problems with vec2web, post here. Please report bugs here.
Locked
Yannick1988
Post by Yannick1988 » Tue Jun 12, 2012 1:59 pm
can you tell me if it's possible to convert a dxf file which contains a picture using vec2web?
Are there some limitations (size of picture, format)?
Thank you.
Re: convert dxf which contains picture
Post by andrew » Tue Jun 12, 2012 2:07 pm
Images are only supported for some output formats:
- PDF: yes
- Bitmaps (BMP, TIFF, JPEG, PNG, ...): yes
- SVG: no
Please note that vec2web has been replaced with the dwg2bmp, dwg2pdf and dwg2svg command line utilities in QCAD 3:
http://www.ribbonsoft.com/en/qcad-docum ... line-tools
Yannick1988
Post by Yannick1988 » Wed Jun 13, 2012 2:21 pm
It seems to only work with PNG pictures.
Locked
Return to “vec2web Troubleshooting and Problems”
