Radiator 'Cover' screen - laser cutting/layout grid
About the creation of DXF / DWG part library items.
Moderator / Drawing Help
Post by Clive » Mon Jun 18, 2012 10:29 pm
Hi Guys
Recently I have been designing some 'Laser Cut' radiator cover screens. Please see attached a dxf file with which you will find a block of the original design and a block of the grid layout which you can use to design your own cover screen design with QCAD :wink: .
The grid can be used to design cover screens up to 900mm x 610mm (with a margin of approximately 20mm). Your own design of shape/s works best if they fit an individual size of 21mm x 20mm.
Simply copy and paste your shapes to the grid intersections.
Radiator panel cover screen - layout grid.dxf
(172.15 KiB) Downloaded 427 times
Radiator panel cover screen smaller.png (126.45 KiB) Viewed 8414 times
layout grid smaller.png (54.89 KiB) Viewed 8414 times
Return to “Creating DXF/DWG items”
