QCAD 3 Final - Debian installation problem
ralvejd
Post by ralvejd » Fri Jul 20, 2012 10:43 pm
Yes nice news :D
I'm waiting for a Debian installation :?: :roll:
Moderator / Drawing Help
Re: QCAD 3 Final
Post by Clive » Sat Jul 21, 2012 12:35 pm
ralvejd
Feature request added:
http://www.qcad.org/bugtracker/index.ph ... ask_id=646
- you can use the 'bug tracker' to add bug reports or feature requests.
Re: QCAD 3 Final
Post by andrew » Sat Jul 21, 2012 4:33 pm
ralvejd wrote:I'm waiting for a Debian installation :?: :roll:
Both the tar.gz and the .bin setup file should work fine under Debian systems.
ralvejd
Re: QCAD 3 Final
Post by ralvejd » Sat Jul 21, 2012 5:37 pm
Ok, just tested the .bin file, same result as before
Moved the installation from /root/opt/qcad-3.0.0-prof-linux to /opt/qcad-3.0.0-prof-linux!
root@pc010:/opt/qcad-3.0.0-prof-linux# ./qcad
./qcad-bin: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.14' not found (required by ./libQtCLucene.so.4)
Bugreport from ambra viewtopic.php?f=34&t=1596
Problem installing on Linux ('GLIBCXX_3.4.14' not found)
Postby ambra » 2011-08-27 09:40:40
qcad-trial-bin requires gcc-4.4.4, but I have gcc-4.4.5, so QCAD fails to start.
QCAD should require major GCC versions (gcc-4.4.x), and not revisions.
Can this be fixed in final release?
Any suggestions on a solution?
Re: QCAD 3 Final
Post by andrew » Sat Jul 21, 2012 5:41 pm
What precise flavor and version of Debian Linux do you have?
ralvejd
Re: QCAD 3 Final
Post by ralvejd » Sat Jul 21, 2012 5:48 pm
andrew wrote:What precise flavor and version of Debian Linux do you have?
pure Debian “squeeze” , last updated yesterday
tyler durden
Re: QCAD 3 Final - Debian installation problem
Post by tyler durden » Thu Jul 26, 2012 12:56 am
The same here :
Debian squeeze AMD64
tyler@squeeze64:~/Downloaded/qcad/tar_gz_version/qcad_3_stable/qcad-3.0.0-prof-linux-x86$ cat /etc/debian_version
6.0.4
And then :
tyler@squeeze64:~/Downloaded/qcad/tar_gz_version/qcad_3_stable/qcad-3.0.0-prof-linux-x86$ ./qcad
./qcad-bin: /usr/lib32/libstdc++.so.6: version `GLIBCXX_3.4.14' not found (required by ./libQtCLucene.so.4)
Which is really funny, because the previous qcad-3.0.0-rc5-prof-linux-x86 has no trouble to start on the same computer.
Guess it will be solved in no time. Maybe i miss some package for the final 3.0.0 stable ?
Thanks for Qcad and your work.
Best.
Post by andrew » Fri Jul 27, 2012 1:07 pm
I've uploaded alternative packages for (X)Ubuntu 10.04, Debian 6 and some other Linux distributions which are not compatible with the regular QCAD packages.
Please check your download area for the packages called 'Linux (Alternative)'.
tyler durden
Post by tyler durden » Fri Jul 27, 2012 3:39 pm
Work perfect now on my Squeeze Debian Gnu/Linux 6.0.4
Thank you very much.
Best.
