Does dxflib retrieve TEXT?
If you are having problems with dxflib, post here. Please report bugs here.
Cambridge Ray
Post by Cambridge Ray » Wed Oct 03, 2012 7:16 pm
dxflib Version 2.5.0
I have tried the test application that is included in the distribution with FIVE different DXF files. All of them contain one string ("Hello World!"). The 5 files have the following versions:
Hello-R12.dxf: AC1009
Hello-R2000.dxf: AC1015
Hello-R2004.dxf: AC1018
Hello-R2007.dxf: AC1021
Hello-R2010.dxf :AC1024
Note: I am only interested in support for R2000.
This is the output:
LAYER: 0 flags: 0
Attributes: Layer: , Color: 7 Width: 25 Type: Continuous
TIA,
-Ramon
Re: Does dxflib retrieve TEXT?
Post by andrew » Wed Oct 03, 2012 7:28 pm
dxflib notifies you with parsed entities and other objects that are found in a DXF file through your implementation of the DL_CreationAdapter interface (dl_creationadapter.h). Please have a look at that class to see what objects and entities are supported. Text is supported through addMText, addMTextChunk and addText.
The test application only implements a small subset of the complete interface to demonstrate how to use the interface. More complex entities (such as texts, hatches, etc) require more effort to implement.
Return to “dxflib Troubleshooting and Problems”
