DxfImporter registration
If you are having problems with dxflib, post here. Please report bugs here.
antoniolc
Post by antoniolc » Tue Jan 22, 2013 4:12 pm
I cannot import/export dxf files using QCad3 version, in open or save dialogs no formats appear.
I noticed that line RDxfImporter.registerFileImporter() on DxfImporter.js was disabled, and on ImportExport.pro was no DxfImporter subdir.
Changing that dxf format appears, but when I try to open a dxf file program crashes.
Also I cannot find an equivalent file to QCad2 rs_filterdxf.
Thanks.
Antonio
Re: DxfImporter registration
Post by andrew » Tue Jan 22, 2013 8:03 pm
Please note that QCAD 3 does currently not have its own DXF importer. QCAD 3 uses the OpenDesign Teigha libraries for DXF / DWG import and export. It is possible (and planned) to port the QCAD 2 DXF import / export based on dxflib also to QCAD 3 for use cases without Teigha, but that has not happened yet.
Most developers choose to extend and modify QCAD through the new QCAD 3 scripting interface. In this case, no new binary is compiled and our Teigha license may be used for DXF / DWG support.
Return to “dxflib Troubleshooting and Problems”
