More self controlled power ...
Post by Husky » Sat Mar 16, 2013 9:05 pm
I like to be the Master of my OWN threads in the Bug Tracker Forum! 8)
Is it possible to give me the permit to handle my own threads regarding deleting threads and/or attachments? :roll:
Re: More self controlled power ...
Post by andrew » Sat Mar 16, 2013 9:26 pm
You should be able to modify your own tasks.
Deleting tasks is not possible at all, not even for me. Tasks can only be closed but never deleted.
Post by Husky » Sat Mar 16, 2013 9:49 pm
Yes, I'm able to modify my own comments but if I delete my text we have still the post headline - what means I leave just trash in the Forum. That can't be ...
You are absolutely sure that you can't change that? If I check my permissions then I see two point what makes me thinking: "There must be a way 8)
Edit - will that help?
flyspray.org/manual:understanding_permissions
(Links are not allowed in this Forum - please copy and past the address into your Browser ...)
Post by andrew » Sun Mar 17, 2013 12:53 pm
Yes, I saw this. These permissions would allow you to delete all comments and all attachments from anyone. There is no way to limit this own comments and own attachments, unfortunately. I can also only change this for all reporters, not for one only. Flyspray is a bit lacking in this respect. How about you add "obsolete" to the task or comment?
Moderator / Drawing Help
Post by Clive » Sun Mar 17, 2013 3:45 pm
Hi Andrew
Some of the guys at work are using this, by their accounts - you can't beat it:
go to > mantisbt.org
It seems to have an impressive range of 'customizable' features for most things.
Hope it helps
Post by andrew » Sun Mar 17, 2013 5:44 pm
Thanks Clive. I actually tried Mantis before flyspray but it was a pain to set up and probably wouldn't have worked at all on our server.
Post by Clive » Sun Mar 17, 2013 5:57 pm
OK, no worries :)
Post by Husky » Sun Mar 17, 2013 8:31 pm
andrew wrote:These permissions would allow you to delete all comments and all attachments from anyone. There is no way to limit this own comments and own attachments, unfortunately.
Funny - isn't it? If I have the permission to edit my own comments - I'm not able to edit other comments, what is absolutely correct!
But if I get the permission (in the same administration) to delete my own comments/attachment than I can delete all comments/attachments off all users?
This logic is different then mine logic :lol:
Thanks guys for your effort - not your fault! :wink:
Return to “Chat”
