Request - Centerline Cross Creation Tool ...
Post by Husky » Tue Aug 13, 2013 9:15 pm
Yes I know - I'm lazy but maybe not only me .... ;-)
It would be nice to have an "Automatic" tool to create a Centerline Cross for circles and arcs.
I could imagine to click on a tool button - click on a circle or arc - give the values for the overshoot and the orientation of the Centerline cross - and done! 8)
If somebody has already a "Centerline Cross Creation Tool" or is able to program one for QCAD it would be highly appreciated if you share this tool with the community in this forum :wink:
Definition of task:
Tool
- creates Center cross lines for circles and arcs (ellipses?),
- Line attributes dependent on active Layer,
- Option-box for overshoot setting,
- Option-box for orientation setting,
- not as a block,
I would do it by my self - but I can't program something like that ... :oops:
... can you???? 8)
J-J
Moderator
Re: Request - Centerline Cross Creation Tool ...
Post by J-J » Wed Aug 14, 2013 10:16 pm
I second you Husky, I could use such a tool as a time saver, but I'm also nill at scripting...
JJ
caigner
Post by caigner » Wed Jul 23, 2014 3:32 pm
I just had to draw centerlines to many circles and arcs, so I support this request. Such a tool would indeed be very helpful.
Idea: The overshoot should be entered either by absolut value or in percent of diameter.
QCAD Pro on Gentoo Linux
